Building a belly tanker
Discussion in 'The Hokey Ass Message Board' started by godspeedbear, Dec 30, 2009.
  1. Bobby Green
    Bobby Green
    Very cool. Good luck with the build.
  2. godspeedbear
    godspeedbear
    from golden
    You ever get the feeling that there isn't alot of space in a tanker ......:rolleyes:
  3. CoolHand
    CoolHand
    Alliance Vendor
    Ten bucks says someone comes along and jumps your case about those yokes not being in phase. ;)
  4. gimpyshotrods
    gimpyshotrods
    If they are run at fixed, zero degrees slope, and exactly 90 degrees to the shafts, it wont be a problem, except for maybe lubrication.
  5. CoolHand
    CoolHand
    Alliance Vendor
    HA!
    Only 11 minutes. :D
    Not saying you're wrong.
    It's just that some things are exceptionally predictable here.
    I would have run a coupling and dispensed with the U-Joints entirely, ***uming the housing is rigid mounted.
  6. uncle johnny
    uncle johnny
    well ron i dont care what they say, i know its a fact now.
    you do have a short drive shaft.
    :D:D
    johnny
  7. freebird101
    freebird101
  8. godspeedbear
    godspeedbear
    from golden
    LOLO Johnny..... Ya I know now that I have to correct the yokes.... fffNg mistake:eek:
  9. power58
    power58
    Looks great, looking forward to next build update.
  10. 53sled
    53sled
    from KCMO
    Gene Winfield uses that same tool to rough in a shape.
  11. Gigantor
    Gigantor
    How in holy hell did I miss this?! Awesome work!
  12. K13
    K13
    Actually zero minutes because you are the one that brought it up. I guess that makes you the predictible one.:rolleyes::D
  13. CoolHand
    CoolHand
    Alliance Vendor
    Damn, hoisted on my own petard.
    Gotta love this place. :D
  14. K13
    K13
    lol:d
  15. This is my mates belly tank.
    All road legal too.
    Got more pics if you want them.....
  16. godspeedbear
    godspeedbear
    from golden
    Love to see any pics you got... they may help me along. :)
  17. draginsteel
    draginsteel
    Thanks for hooking me up with that metal meet site.
  18. godspeedbear
    godspeedbear
    from golden
    No prblem. Good guys, they'll help with just about anything..
  19. gimpyshotrods
    gimpyshotrods
    x2:)
  20. godspeedbear
    godspeedbear
    from golden
    Still working on frame kinda stuff, still have to make some tie rod ends.. There's alot of stuff going on in the nose of this thing.. and got to start to mount the body..:D
  21. godspeedbear
    godspeedbear
    from golden
    I started to weld the locating ribs in today. I made them out of three pieces to help eliminate some s**** that I had laying around
    And a pic of the mounting points
    And one that I thought was pretty neat, the 'swoop' at the back end
  22. godspeedbear
    godspeedbear
    from golden
    Some more pics
    I got a little more mock up done, the bottom is mounted and I'm now just checking to see how the top is going to fit.. KInda looks like having a killer whale in the shop...:)
  23. rat seeker
    rat seeker
    This is an unreal project, keep up the good work.
  24. godspeedbear
    godspeedbear
    from golden
    Thanks for the input.. I'm just stuck in the tedious work...Might be a pic update Sunday.:)
  25. godspeedbear
    godspeedbear
    from golden
    You ever notice that for every hour that you spend on the 'skin'; you have to spend 3 on stuff that noone will ever see?[​IMG]
    I'm still working on all the body mounts and 'stuff'. Here you can see the air scoops that will eventually feed the engine and the other side will be air for the driver.
    The rear is starting to take shape as well, still fighting fitment issues
    There's space but I still have to use it wisely[​IMG] The engine tucked nicely into place and I found out that my 'shot gun' pipes are too short. These things are taking up quite a bit of time..
  26. JGRAFF
    JGRAFF
    WOW this thing is really taken shape. I love it!!! Awsome work. I worked as an aluminum tig wleder for awhile so i know how that metal workes. not easy. way to go.
  27. godspeedbear
    godspeedbear
    from golden
    It's a lot of stuff under the skin... the heat vents that allow the rad. heat to escape, and the rad. support
    and a bulk head
    Then you have the header and the opening in the body
    And a support rib that I need to attach...
  28. thebraus
    thebraus
    beautiful man, just beautiful.
  29. Hot Turkey
    Hot Turkey
    Damn dude! Kick ***!!!!
  30. Streetwerkz
    Streetwerkz
    Nice werk!!
    keep at it
