TECH...well sorta... JAG IFS into mid fifties F100
Discussion in 'The Hokey Ass Message Board' started by Tall Paul, Feb 28, 2010.
  1. I always see guys asking here on the HAMB about how and what clip to put in the front of their ride, so I always have a bit of a look and am blown away by some of the complexity of some of these installs!! So I thought I'd show you how I did one of the worlds easiest front end upgrades on my 54 F100.
    I know there have been some threads on here about the JAG IFS front end, but I'll just quickly re-cap for those that haven't seen. In Oz, New Zealand, and the UK, the JAG front end is an extremely popular front end swap into hot rods, customs and trucks. It is a really neat piece of kit. It is a complete crossmember with big discs, 4 piston calipers, heavy duty made to suit the JAGs, power steering, and has chevy bolt pattern, which is easy enough to change to ford if you want. Another neat feature of it is it is quite low slung, so pretty much attaching it to the undeside of near any ch***is will set the car quite low. If it still isn't low enough, just notch the ch***is out a bit, or install a set of bags which fit neatly into the JAG front end too....what ore could you want? :D
    So here goes....
    First get yourself one of these, a series II or series III JAG. This one cost me $300 with no motor or gearbox but pretty much complete.
    From here you literally undo 4 or 6 bolts and the whole front end comes out! While you're at it, you may as well grab the rear end out too, get the wiper motor too (it is a neat remote unit with cable drive, works well in rods where you don't have room up top for a big motor), and get the top unit joint off the steering column so you can adapt it later on to the rack. I later sold the rear end for $300 and s****ped the rest so got my front end for nix.
    This is what it looks like fresh out the car, on the bench ready to clean up.
    Some people rubber mount the whole crossmember to the ch***is and fab up forward and rear mounts, others just clean it up and weld it straight in. I chose the later, so cut off anything that didn't look like it needed to be there :D
    The F100 ch***is is 34" wide and fouls the inside of the controls towers by about 3/4" each side so a couple of relief cuts needed to be made, as indicated below.
    I marked the centreline of the front axle on top of the ch***is. I then made a mark 35mm forward of this (1 1/2") to centre the wheels properly in the wheelarch. I tacked a piece of square tube across the top of the crossmember so i could line it up with the centreline marked on top of the ch***is. The crossmember fits quite flat under the ch***is rails, with a slight rearwards caster. This will be bought back to zero once the truck sits at ride height.
    I tacked it in, threw on some wheels and lowered it off the stands. The unweighted front end ends up sitting the factory gearbox crossmember about 6 inches off the ground. With engine, box, cab etc in and the weight back over the front, should bring this down another couple inches and sit the truck pretty low :) All that's left to do now is box the front sections of the ch***is rails and fab up some gussets to hold the crossmember in properly.
    And that's how a JAG front end goes under a 50's F100 :)
    Cheers,
    Paul
  2. crackerass54
    crackerass54
    from dallas
    Are you going to use the right hand drive in the truck or swap the rack? What year JAG or are they pretty much the same?
  3. Strange Agent
    Strange Agent
    Looks good. I keep hearing good things about these front ends. I'm going to keep it in the back of my mind.
  4. willymakeit
    willymakeit
    This is a keeper. Thanks
  5. I have installed a Jag front and rear in my '49 Lincoln.
    500 Caddy powered as well.
    The result is amazing.
    4 wheel disc brakes and a perfect ride.
    What more could you ask for.
    Yes, they are very popular for transplants here in New Zealand.
  6. 38FLATTIE
    38FLATTIE
    from Colorado
    Way cool- Thanks! I just picked up a Jag front, and a 3.54:1 posi rear to put in my 38 Lasalle, so this thread comes in handy.
  7. Yeah i'll leave the right hand rack in the truck as it's easier to licence like that here in australia. A friend of mine has a lhd pickup so put the same front end in, and just swapped the rack over for a lhd one....his was already licenced tho :)
    As to what years series II and series III jags were late 70's to mid 80's i think, and as far as i know, they are all pretty much the same. I think in one of the other posts on the HAMB about the jag front end into a buick, someone posts up all the specs on the front ends for what year jags.
  8. fab32
    fab32
    It doesn't get much simplier than that.
    Frank
  9. Oh yeah, I still have to make upper shock mounts and mount the sway bar later once engine and everything else is in place.
  10. Please post some pic's once it is on the ground so we can see the stance.
  11. A pic of mine might be WAYYYY off, so here's one until then. The blue 56 on the left is a mates f truck that has the same JAG front end put in exactly the same as I did (not my pic, borrowed from another site) Sits really nice and drives great.
  12. Seems easy enough.....Thanks.....
  13. fitzee
    fitzee
    cool setup.I wonder what the cost is to out fit the front brakes on a Jag?
  14. Rusty
    Rusty
    thanks for sharing
  15. Man, these Jag posts are so dangerous! Every time I see one it makes me want to take a sawzall and hack the Mustang II out of my '55.
    BTW, that pic. in post #11 is awesome!
  16. Racewriter
    Racewriter
    I wouldn't have been able to resist hanging that gorgeous rear end under it too. Thanks for the info. Jag suspension appears to be a dirt-simple swap, and it's on my "to do" list. "To do" to what, we don't know yet.
  17. <meta http-equiv="Content-Type" content="text/html; ch****t=utf-8"><meta name="ProgId" content="Word.Do***ent"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDO***E%7E1%5CGayle%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDo***ent> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:EN-AU;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> How do work out if its fitted at the right angle? Is it level in both planes- level across the cross member and level front to back on the cross member?
    <o:p></o:p>
  18. zman
    zman
    from Garner, NC
    that's how the one on my Buick came out of the Jag and went into the Buick.
  19. trammel
    trammel
    I have always liked the jag swaps. What is good about these they use ****er part numbers. Good job
  20. grovedawg
    grovedawg
    from Heber, UT
    Sweet post. Thanks
  21. burger
    burger
  22. zman
    zman
    from Garner, NC
  23. flamed34
    flamed34
    The front ends from '72's (series I '69 to 72) are the same as the series II. I've used a '72, and currently using a '74 and they are identical.
    Someone asked about the brakes...they are pretty cheap (rotors $69, caliper rebuild kits $22) at Coventry West. On our '51 with the '72, we made adapter plates and used Corvette calipers for additional braking - but this time around, I'm using stock calipers.
  24. Yeah there r slight differences between series I II and III. Series II and III have 4 pot calipers, and apparently one of the two is more desirable to convert to ford bolt pattern (well out here in OZ anyway guys convert to falcon discs and GM calipers i think by way of machining the stub axle) As i'm leavin it chev bolt pattern and basically stock i didn't look to much into the exact details for converting it. If you are intersted, google it cos I'm sure there are a couple of discussions on Ozrodders.com about it.
    As far as setting it in the ch***is, like what ZMAN said, I set the ch***is at the rake I wanted (level front to back) and then set the crossmember level or horizontal, actually i shoudl probably write that a different way, set the crossmember horizontal, and then set the ch***is around it to whatever rake u want. I wanted the ch***is level hence setting everything this way.
    If anyone has any general fitting a JAG front end questions, maybe just doa quick google search, and a quick ozrodders search. The aussies, kiwis and Poms have been doing this swap for years and there is tonnes written out there about the swap, and also modifying it for different purposes. Apart from that, I'm more than happy to offer what limited knowledge I can :)
    Cheers,
    Paul
  25. Deuce Roadster
    Deuce Roadster
    Any updates ??
    :) :D
  26. Yeah I ended up getting it all tacked in there and lookin pretty, just needs finishing off. I won't be doing the finishing off though cos I just picked up and moved to So-Cal and left the effie in Australia :) But I would definately consider doing the swap again though on a 50's truck if I get one again.
  27. Waldoz
    Waldoz
    What is the bolt pattern on this suspension? I know everyone is saying chevy, but is it 5 x 5 or 5 x 4.75? I'm looking at making this swap on my 46 Stude P/U.
  28. zman
    zman
    from Garner, NC
    4.75
  29. Waldoz
    Waldoz
    thanks, zman
  30. almost the same stud patten, you should check. I have seen some were the wheel fits on but the stud wasn't in the center of the hole so when the lug nut was done up it put stress on the stud.
