Projects '40 Ford frame repair, Welding advice?
Discussion in 'The Hokey Ass Message Board' started by 27T, Jan 24, 2010.
  1. Looks like my 39 Mercury frame, it's rusted through on the same spot.
    Mine was full of sand, dirt and other sh.t
    No reason not to weld it, after all it's only metal
  2. 27T
    27T
    almost done with the outside of the frame, just a few spots to fix on the "X", hopefully rolling soon.....
  3. koolkemp
    koolkemp
    Looking good man!
  4. HiSpoke
    HiSpoke
    Here are some pictures from my 40 frame repair.
  5. roughidle
    roughidle
    from iowa
    I would fix that myself. The reason people say you need a jig is because frames will warp when you weld on them. I use a 4x8 table made out of wood (built like a brick **** house) some s**** angle iron over top the rails screwed down to the table. Built frames this way several times and no warping. Works good.
