Flared Holes ,the easy way !
Discussion in 'The Hokey Ass Message Board' started by KUZTOM, Mar 2, 2010.
  1. Drive Em
    Drive Em
    I have a tool that is basically the same that I built to fold the edge under on stock car wheel openings, but I never thought of using it on smaller holes. Nice tech!!
  2. Black Primer
    Black Primer
    I'm savin' this one ...thanks!
  3. unkledaddy
    unkledaddy
    Super-Tech................Thanks.
  4. KUZTOM
    KUZTOM
    Kevin ,Ive seen these before ,I hear they do a real nice job.that sort of gear is hard to get over here, unless you bring it in urself.
  5. unkledaddy
    unkledaddy
  6. with.disdain
    with.disdain
    Yeah, but any combination of beat-to-hell drill press, poor quality drill chuck, poor quality hole saw, or thin sheet metal can make things more challenging. I sometimes don't have control over enough of those factors to ensure it'll work properly.
    I also do a lot of work on sheet aluminum. There usually isn't enough material bearing on a pilot drill to ensure everything stays aligned. I usually need to have some thicker backing material or other tricks - like the plywood pucks.
    I like the look of the flared holes on your ride.
    Brian
  7. Looks like a winner Steve,
    I better have a shot at it myself.
  8. fordsteel
    fordsteel
    from Elkland PA
    Its the simple things in life ..... like making 25 cent homemade tools..... really sets our hobby apart. great job
  9. KUZTOM
    KUZTOM
    Correct 101% , I dont have flash gear ,but I get by...........;)
  10. Big Jon
    Big Jon
    Mate , like the article in the latest nz hotrod mag, well done
    Jonno
  11. cheezwiz
    cheezwiz
    Recently someone told me to drill my pilot hole, then replace the drill bit with some 1/4" rod to prevent "walking" It worked for me !!
  12. This is the only way to use a hole saw in sheet metal. No mucking about with backer blocks or using mills. Just drill the 1/4" pilot and stick a piece of 1/4" rod (cold rolled or drill rod works best as it varies in size less then hot rolled) in the hole saw arbor and no more wandering. If you can get to both sides of the material cut halfway through from both sides and you will have much less burr left around the hole.
    Jaysin
    P.S. Super great post about the flaring by hand. There have been many occasions that I have wanted to flare an odd sized hole and this is easier then my way. Thanx
  13. bobx
    bobx
    from Indiana
    nice tech. thanks
  14. flt-blk
    flt-blk
    from IL
    I've used this method to flare oval and other not round shapes where a dimple die won't work.
    nice job.
  15. fab32
    fab32
    How thick of materiel have you used this on? I can see it being limited to sheetmetal or slightly thicker. Cool tech.
    Frank
  16. Gahrajmahal
    Gahrajmahal
    After spending my lunch reading the build of the roadster pickup by Kuztom and his son, Hot Rod Kid, they get my vote as Tech week winners. Too many cool ideas. Check out what they do with the steel toe inserts from workboots, and the bicycle fork light bar. Brilliant!
  17. That, my friend, is called "Kiwi Ingenuity" .... :D
  18. KUZTOM
    KUZTOM
    Thanks very much for taking the time to have a look, & the kind words.
    I suppose we could throw the above idea's into this Tech Week Thread also.......
    We had some steel toe caps from work boots given to us ,so we used them for mounting the 39 Chev tail lights....
  19. attitudor
    attitudor
    from Finland
    Damn, that's clever!!! Thanks!
  20. KUZTOM
    KUZTOM
    With the Head Lights, which are from an old Railway Jigger, we used a combination of old 1940's Bicycle componets, seat & handle bar stems, plus forks, once fitted ,we had a clearance issue,so the trusty steel to caps came in use,to raise things up a tad....
    As you can see ,its all very simple stuff, This whole build was about using stuff in the shed, giving every thing a go ,and having heaps of fun !;)
  21. Fullblast
    Fullblast
    How do you do the rivits, with a air chisle and some kind of back tool?
  22. KUZTOM
    KUZTOM
    Frank Hi, I have use it on various sheetmetals, the challenge is on thicker stuff, the tool tends to open up a tad in the 'jaw', but really its for doing just simple flares in light to medium grade sheet.
    Steve
  23. KUZTOM
    KUZTOM
    All by hand , had to shorten them first, then just tapped away with a ball pein hammer , easy as ,just takes time.....;)
  24. KUZTOM
    KUZTOM
    Clive , cheers , get some holes in that LINC !:p
    Big Jon , thanks for that ,Bill is a bit pissed at the moment ,he's 14 , now they talking about putting up the driving age ........
  25. KUZTOM
    KUZTOM
    Im working on another part, once I get it done,I will post up the pic's....
    Please check back later ;)
    Steve
  26. Hot Rod Michelle
    Hot Rod Michelle
    Very cool. Looks easy enough that even I might be able to try it.
  27. Scumdog
    Scumdog
    Meh, I'd rather go to the hardware store and buy a big packet of pre-flared holes and pre-made lips...:D
  28. spobanz
    spobanz
    Cool idea! Thanks.
  29. RopeSeals???
    RopeSeals???
    I had to do a double take on the headlight supports/bike handlebar stems, on first glance they looked like something you'd see on a vintage aircraft... Well done!
  30. KUZTOM
    KUZTOM
    haha ,and welcome to the HAMB Tom,a tad more action on here than our other one :p
