Bonneville styled 1932 tudor build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Oct 17, 2009.
  1. KENDEUCE
    KENDEUCE
    I just keep coming back and go WOW!!!! Cool ride. Waiting for open house details when you get to it. Thanks for the work of posting pics.
  2. noboD
    noboD
  3. vintagehotrods
    vintagehotrods
    Just get a big piece of saran wrap for those rainy days!
  4. chopt top kid
    chopt top kid
    If you're runnin' fast enough, there ain't no rain gonna get thru those louvers... I'm likin' this build more and more every time I check this thread, those louvers are right on. I'd be tempted to paint it red and screw on a set of moon discs... Keep up the good work...
  5. hechtspeed
    hechtspeed
    Chris, this thread on your ride just puts a smile on my face. You're going to blow it up in August man! I can't wait to shoot it on the salt! ;) I gotta post some updates on the blog asap. So, what's next after the louvers?
  6. After hearing it 100 times from everybody else, I don't know if me saying this really matters...but that is a really nice car!
    You're doing a first cl*** job and giving it a personality of it's own. Sucessful build to say the least! haha.
  7. Salt Flats Speed Shop
    from Utah
    Thanks everyone for the comments. Im just glad everyone is liking the car so far.
    The sheet metal on the car is almost complete except for the floor. I now need to figure out the pedals, and steering.
  8. Salt Flats Speed Shop
    from Utah
  9. Anderhart Speed
    Anderhart Speed
  10. bonesy
    bonesy
    Those louvers on the top insert look so cool. I love it!
  11. coopsdaddy
    coopsdaddy
    from oklahoma
    How do you plan to finish the top(weld in ,duez,etc)
    I have a insert for a model a i am thinking about louvering but want to be able to remove it
  12. Eddie's chop shop
    Eddie's chop shop
    Wow its like deja vu... you put a few more in though
  13. Eddie's chop shop
    Eddie's chop shop
    and people told me my press wasn't big enough....
  14. Eddie's chop shop
    Eddie's chop shop
    your making good progress, last time I looked you were still deciding on the chop
  15. O U T S T A N D I N G !!!
    Right click, save, .....right click, save....
    Rat
  16. GaryB
    GaryB
    from Reno,nv
    wow this is some amazing work awesome thread
  17. Southfork
    Southfork
    [QUOTE Im trying to go for more of a barn find look with this car so im trying to find original parts that are a little crusty.[/QUOTE]
    Looking real good, Chris.
    I noticed that you brazed an original radiator fill into the '32 grill shell so that you can put an original 32 radiator cap on, while maintaining a pressurized cooling system. That's pretty trick. Did you find the 'crusty' radiator cap and bezel/ceramic Ford script you were looking for yet? If so, why not post a picture of the cap etc. on the radiator? I'd like to get the flavor of how "barn-find" the ornamentation will appear.
    By the way, what guage aluminum did you use for the top insert?
  18. Salt Flats Speed Shop
    from Utah
    By the way, what guage aluminum did you use for the top insert?[/QUOTE]
    Thanks, I thought that would be the easiest way to still be able to have a stock radiator cap and not have to attach it to the radiator. I borrowed my buddies original cap to get it brazed on, but im still looking for one. I would love to find a pickup cap cause they were painted so they usually have really good patina plus it would match my pickup grill. Also looking for an emblem.
    The aluminum is .063 3003 h14
  19. Salt Flats Speed Shop
    from Utah
    I got the motor mounted today. I cut out a mount that bolts to the front 4 bolt holes on the front of the engine. And then has feet that bolt to the top of the cross member with some rubber pads in between. That way I can just smooth out the water pumps.
    Then I started mocking up my headlight bar height. Getting ready to transition that into the frame.
    [​IMG][​IMG]
  20. -Brent-
    -Brent-
    That's some thick steel, what did you use to cut it, Waterjet? Soften that bad boy up and it'll look right at home!
  21. Salt Flats Speed Shop
    from Utah
    Had a local place cut it with a laser. Really clean cuts, and fair prices.
  22. TAYLOR
    TAYLOR
    from DALLAS,GA.
    Great build, thanks for posting.
  23. Buddy Palumbo
    Buddy Palumbo
    bad *** ... looks good !
  24. Black Widow Customs
    Black Widow Customs
    from TUCSON,AZ
    *****in hot rod .... cant wait to see more progress
  25. krimsonghost
    krimsonghost
    I just came across this thread tonight, a gl*** of Jameson later I finished it. I am truly in awe of your metal working skills. Hopefully one day I'll be half as good as you. Plus you don't look any older than me (I'm 26). Car looks absolutely killer, and if I ever make it out to speed week, would love to come and check out your shop. By the way, I believe Coker is making repro tires like that. (just in case you burn those ones up!)
    http://store.cokertire.com/tire-styles/other/dirt-track.html
  26. krylon32
    krylon32
    from Nebraska
    I asked **** Spadero about the 32 PU radiator cap and he said that gennies were very rare and that someone stole the gennie cap off his truck. According to **** the closest thing to a duece rad cap is a 30/31 A gas cap. He said they dam near look the same and would fool most people.
  27. DavidL
    DavidL
    The headlights low like that take this too a new level of bad ***.
    [​IMG][/QUOTE]
  28. Salt Flats Speed Shop
    from Utah
    I worked this morning on the hood latches. I had to modify the originals by lengthening the lower arm, and then heating and bending it so that the bracket could be bolted to the side of the frame. It works great, and has a nice original feel.
  29. Salt Flats Speed Shop
    from Utah
    I worked on leading the seams on the p***enger door. Its ready for body work.
  30. Salt Flats Speed Shop
    from Utah
    Got the drivers door leaded up today as well.
