BSA Pinewood Derby Car Builds....Slightly OT but it is RACING
Discussion in 'The Hokey Ass Message Board' started by Pontiacres Ranch, Feb 25, 2010.
  1. Pontiacres Ranch
    Pontiacres Ranch
    Killer Headers Toby
  2. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,I never got to do that when i was in Cub Scouts in the early '50's ,,so it was a treat to help Charly with his ,,,loved it ,,great fun,,,
  3. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Gonna give away another speed secret,,,we filed groves in the middle of the nails that held the wheels on ,,to hold more graphite ,,Sorry Charly ,,Gotta Help those coming up ,,
  4. Pontiacres Ranch
    Pontiacres Ranch
    They're on to you...grooved and tapered Axles are not allowed....but you can polish the hell out of em!
  5. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Hhmmmm,,,,oh well ,how 'bout instead of polishing em ,,ruff em up with sand paper / emory cloth to make fine little groves on em ,,will hold more graphite that way too ,,an old Grumpy Jenkins trick ,,i did that to my rod n main bearings in my old C/Gasser 396 BB in the late '60's to hold more oil ,,Hhmmmmm ,, " Shade Tree Engineering "???/
  6. Pontiacres Ranch
    Pontiacres Ranch
    Thanks for keeping this goin everyone. Logan saw that over 2000 people have looked at this and he says "Im Famous".....had as big a smile as after he cut out his 1st practice side on the Scroll Saw!
    More tomorrow!
  7. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Hey Kool Man ,,keep us informed how it goes ,,,hope he wins ,,,and He can be famous ,,!!
  8. Pontiacres Ranch
    Pontiacres Ranch
    2-Much update......
    Clamp It Jed! ......I mean Logan!
  9. Toby Denham
    Toby Denham
    from Georgia
    Thanks. They're made of pieces cut form wire coat hangers and pieces of aluminum tubing. :)
  10. Pontiacres Ranch
    Pontiacres Ranch
    Derby Car Time! Hollow the cockpit, round out the ass end.....hit it with a bit of sandable primer!
  11. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Hey,,Don't Ferget the reverse wing on the back ,!!
  12. Assdragger
    Assdragger
    We need a custom!!
  13. Assdragger
    Assdragger
    another
  14. GREASEMONKEY72
    GREASEMONKEY72
    i love pinewood derby cars
    ill have to take pics of mine later
  15. Toby Denham
    Toby Denham
    from Georgia
    I don't know if anyone else mentioned this, but I will just in case they didn't. You can true the wheels by inserting a 2" long machine screw that will just fit through the wheel with a nut gently tightened on the backside (hub) then inserting the the machine screw into a drill so the wheel can be spun against sandpaper held on a flat surface. It will make the wheel perfectly round.
    Another trick is filing down the little ridges you'll find on the underside of the nail heads (axles). Doesn't take much. I used a points file.
    Man, I need to have another baby boy so I can do this stuff again! :)
  16. Toby,
    Where are you in GA???
  17. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Another trick ,,,file down the edges of the tires ,,slightly ,,so they only run on the little centers ,,less drag means more speed ,,,hope THAT'S legal today ,,
  18. rusty76
    rusty76
    from Midway NC
    I tried my best to get my soon to be stepson to do the pinewood derby for the scouts. He decided he didn't want to do the scouts anymore and so we didn't get to build the car. So now in the back of my mind I want to build a car just for fun. Right after he decided to quit I made him look at some of the pinewood derbys on youtube. He couldn't believe what they were doing, but still he didn't care. Oh well.....no hot rod gene I guess.
  19. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Rusty76; Neon Charly is my youngest son ,,my oldest Curt ,,didn't wanna do the pinewood derby thing either ,,and quit cub scouts ,,we/I didn't know 'till much later he was deslesic,,(SP ) ,,all the letters appeared backwards to him ,he just couldn't read right,,,so ,,,years later after we fingered it out ,,he look special courses to help him ,,he ended up in the Navy after Hi School,,a Diesel Engine Specialist and now werks for the City Of Jacksonville ,Fla ..
    not saying that's your step sons problem ,,,but check it out ,,
  20. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Oh ,,i know there's a weight rule ,,,but ,,,drill a hole in the nose ,,put a fishing lead weight in it , cover it with wood fill ,,weigh the car ,,take weight offa the rear to make it legal ,,the more weight on the front ,,the faster it'll go ,,
  21. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,GOOD LUCK LOGAN ,,,Go Fer It ,,,!!!! we're ALL Chearin' For You ,,BUT ,,remember ,,,If You DON'T WIN ,,there's Next Year ,,it took my son Charly two years before he got the "Blue Ribbon" ,,
    It Takes Just As Good A Sportsman To Loose as it Does To Win ,,we ALL lost first ,,before we Won,,
  22. CONNMAN,
    Where you put the weight depends on the track you're running on- most are 50/50 now (50% drop and 50% flat run). If you put the weight in the front on one of those tracks, the car will go great until you hit the flat run... then slow down because the car is trying to push the weight.
    "The books" say to put the weight just a bit in front of the rear wheels, putting the balance point about 1/2 to 3/4 inch in front of the rear wheels... we'll see in a few weeks.
  23. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,O K ,,i thought the tracks were all 'posed to be the same ,,
  24. Coupe-De-CAB
    Coupe-De-CAB
    from Nor Cal
    cool thread ...mine from 3 years back:)
    Hamb represent!
  25. Buick59
    Buick59
    from in a house
    This was my sons last one he built. It was loosely based on the Red Head.
  26. Pontiacres Ranch
    Pontiacres Ranch
    Not as much progress as we'd hoped, Seems that it's easier to concentrate after dark than early, but I can't blame him for wanting to be outside.
    Its sitting on some Non Reg wheels and Axles, but its for motivational Pics only.
  27. Diesel627
    Diesel627
    Ahhh this thread brings back good memories! I remeber making multiple pinewood cars with my dad. It's cool to hear others talking about lead and graphite, because that's what we used. I ended up getting 2nd place in my council (Indian head).
  28. CONNMAN
    CONNMAN
    from Lampe,Mo.
    >>>>>,Ed; lookin' great !!! the kids doing really good ,,,
  29. olskoolrodder
    olskoolrodder
  30. sinful-one
    sinful-one
    You've made some nice progress. Heres some shots of one that I have in the works.
