I found this brake/ metal folder. What are the applications and is is it any good for general metal work on a vehicle?
It's called a bar folder. It can do a low depth full 180 brake. Good for replacement deuce grill bars.
I'd like to see some better pics of it. Kind of hard to tell what it is/does. It looks like it says "22ga mild steel" under the brand? If that's the case, it won't do much for automotive stuff. Probably more of a ductwork or other tinwork tool. jw
You can see the piece I folded with it in the second picture. i think you could do 20ga no problem. I wonder what else could be done with it? What was the original use?
Yep I just bought an old 14ga Whitney Jensen 4' combination box pan brake from an equipment dealer and the book for it shows doing 180* and inter locking folds as well as 8" deep box's, radius bends ect. Take delivery next week along with a 52 Wysong stomp shear Kevin LFD Inc.
