62 Galaxie question
Discussion in 'The Hokey Ass Message Board' started by LunaticFord, Mar 3, 2010.
  1. LunaticFord
    LunaticFord
    I have a BW T10 that I want to put behind the 352. I was curious if the 4 speed equipped cars had anything different about the trans tunnel. I see Crites has fibergl*** trans tunnels, but every 4 speed 62 I've seen looks pretty much like mine. Other than the hole, what else needs to be done?
  2. FrozenMerc
    FrozenMerc
    The hole should be the only thing you have to do. The Cruis-o's were big chunks of cast iron, larger than the T10 I believe. You may have to modify your trans mount though.
  3. LunaticFord
    LunaticFord
    It has a T 85 3 speed in it, now. I think they're similar externally. Go ahead and correct if I'm wrong.
  4. arca39
    arca39
    from summit il
    i think the rubber mount has to be turned 180 deg... driveshaft might be smaller on the 3sd.(not 100% sure).
