small block chevy exhaust in 1950 shoebox?
Discussion in 'The Hokey Ass Message Board' started by sanchez, Mar 5, 2010.
  1. sanchez
    sanchez
    from N.C.
    I'm trying to figure out what header will clear the steering box in my 1950 shoebox that's housing a small block 307? Any help would be greatly appericated, thanks....:confused:
  2. brad chevy
    brad chevy
    Have you looked at a set of what are referred to as shorty hedders.they work on most applications.they hug the block pretty tight.
  3. sanchez
    sanchez
    from N.C.
    are those a stock gm brand or aftermarket? where do they dump? in the center or the rear?
  4. Deuce Roadster
    Deuce Roadster
    This is a set of Shorty type headers. Most decent hot rod shops have them :) ... and eBay :cool:
    1984 to 1991 Corvettes had basically the same thing
    Cut the smog contol tubes off, weld up the holes and they look like this.
    They are usually on eBay for 25 to 50 dollars a set. I believe that the Corvette ones actually tuck in tighter than the street rod aftermarket ones ... :)
    http://cgi.ebay.com/ebaymotors/C4-C...r_Truck_Parts_Accessories?hash=item20afceec29
    And NO this is NOT my auction ... just aheads up :D
    Chevrolet used a LOT of different exhaust manifolds that fit a SBC over the years. Some exit the middle, others exit at the rear. Some can be switched so they exit at the front.
    V8 Monzas had about the tightest fitting iron exhaust manifolds I remember seeing ... shown below.
    Left side and Right side exhaust manifolds interchange ( on the engine ) ...
    So if you see a manifold that will fit your engine AND will fit in your frame ... it does not have to be a specific side ( L or F )
    You also MAY want to LOOK at moving the entire engine/transmission over a inch or so. Many cars came from Detroit with the engine offset to the right ... The SBC in my 32 Ford is moved over about a inch to gain clearance for the steering shaft.
  5. GreasyDave
    GreasyDave
