Projects Made a little Hercules progress today
Discussion in 'The Hokey Ass Message Board' started by biscuit eater, Jun 13, 2009.
  1. biscuit eater
    biscuit eater
    Street only, road trips etc. Any chance you could modify a couple of those blocks for me?
  2. J'st Wandering
    J'st Wandering
  3. BinderRod
    BinderRod
    When you mount your track bar I would box in the section of the frame for a little more support for the bracket.
  4. biscuit eater
    biscuit eater
    yes;), I'm planning on boxing most of the frame.
  5. WelderSeries
    WelderSeries
    Alliance Vendor
  6. woodman
    woodman
    Nice! I admire your work. Where are all these nail heads coming from. I can't find one in my area. Seems like people can just pull them out of their ***.
  7. LOW LID DUDE
    LOW LID DUDE
    from Colorado
    I think you in the future will ask yourself why did I shorten the length of the cab? I built a 32 Ford pu and extended the cab 12 inches after driving it several years short.The extra room was fantastic and made it a lot more comfortable to drive.A little chop would look nice also but that is a personal choice. I like what your doing but you may want to rethink it before ya get too far to change If you are planning to drive it a lot.Just my 2 cents thought from someone that has been there done that.
  8. biscuit eater
    biscuit eater
    Thanks for the support! This is my first build of this magnatude so I'm learning as I go along. I see nailheads pretty often in the Hamb ads and the 'bay, you just gotta keep your eyes peeled.
    Thanks for the feedback! I decided the wheelbase was just too long, and it's still going to pretty long as it is. I'm only 5'8 and I spent a good long time sitting in the cab with the seat in it. The cab is a little wider that most because of the way it's made and with the unchopped top I can sit more upright. My previous project was a '45 Jeep (it's in my profile) that thing had a serious leg room problem, so I'm building the truck to fit me. I really think it'll be fine.
  9. Are you making any progress???
    -mikethegreek-
  10. 39plymouth
    39plymouth
    wow impressed i really like the idea of this i always wanted a truck of that era but being 6 4 most are too small ... one day id love to tackle one like this..
  11. biscuit eater
    biscuit eater
    Yeah, I'm creeping along. Made a few more tweaks to the cab to make it fit the frame better. Got a permanent ****** mount in there (not the prettiest one I've ever seen but it'll work for now), got the master cylinder/brake pedal ***embly figured out and ready to weld in. Supposed to pick up my front axle this weekend with all the bushings/holes etc. installed and reamed properly.
    Hey thanks! It's a "coachbuilt" cab, a little wider than a production cab, and very easy to add length behind the doors.
  12. Sweet! Keep on keepin' on!
  13. alwaystiredlong
    alwaystiredlong
    I like the wheels!
  14. Rocketile
    Rocketile
    from USA
    Nice metal work... can't wait to see the end result!
  15. pasadenahotrod
    pasadenahotrod
    from Texas
    That is NOT a roadster/phaeton cowl, it is 30-31 Model A Ford cowl which was used on U.S. Mail Trucks and sold on AA truck cowl and ch***is to aftermarket body builders.
  16. biscuit eater
    biscuit eater
    Thanks! I'm pretty much a hacker, but I'm getting there.
    Thanks for the input. That jives pretty well with what the p.o. told me about the cab. That's were I got the "Hercules" in the ***le of this thread, that's what he thought it was. Ford cowl and ch***is with Hercules aftermarket cab.
  17. pasadenahotrod
    pasadenahotrod
    from Texas
    Throughout the years Ford has offered cowl and ch***is truck units to the aftermarket for use, primarily through the 60s as school buses. In the T and T and early V8 era there were many makers of moving vans, stepvans, armored cars, and other commercial applications who bought these cowl/ch***is setups. Ford, GMC, Chevrolet, Dodge all offered a version of the cowl/ch***is truck.
  18. biscuit eater
    biscuit eater
    Permanent coilover brackets, much nicer than those blue things I had on there. I have some clearance issues here but I'll get it.
  19. zmcmil2121
    zmcmil2121
    Sweet truck. I love how the mock up looks so right that if it is wrong, I don't wanna be good.:cool:
  20. biscuit eater
    biscuit eater
    Hey thanks man! I can't wait to get it sitting on four wheels!
  21. biscuit eater
    biscuit eater
    Managed to drill my drums today to fit the new hubs(thanks Eric) and get the correct bolt pattern for my wheels. Gotta get some longer bolts.
  22. duste01
    duste01
    Did you get all the welding done that you needed?
  23. biscuit eater
    biscuit eater
    Not yet, but it looks like Ratrodder34 is going to hook me up.
  24. ratrodder34
    ratrodder34
    from Irvine,ky.
    Just let me know when you are ready.....will most likely bring over to my place if its okay with you :eek:
  25. Looks good dude! Are you mounting the spring from the bones?
  26. biscuit eater
    biscuit eater
    Thanks! Yes, the spring will be behind the axle and attached to the bones.
  27. biscuit eater
    biscuit eater
    I've been waiting for parts and finally made a little progress...
    Got my brackets made and did a test fit...
    I thought they came out pretty nice for my first try,
    Sitting on all four wheels and full suspension for the first time, woo-hoo!
    Here's the brackets after some shaping and smoothing,
  28. Okie Pete
    Okie Pete
    Thanks for sharing your build. Looks great.
  29. 41 Dave
    41 Dave
    Man, I like the look of you parts you made to hang the spring off of the wishbone. Looks like it should be real low. Looking forward to the next update.
  30. brigrat
    brigrat
    from Wa.St.
    Is this what you started with?
