so ive been doing some research and havnt come up with an answer...im working on a 62 belair 4dr street rod project for my dad, and am trying to see what kinda of donar car i need to swap front to disk, id like to do it this way in hopes that the car will have motor trans and rear end also...im thinking somthing like early 90's caprice but not sure....any info or sites that have interchanges would be appreciated.....thanks steve-
I did disk on an 62 Impala. I think I used 69-72 chevelle rotors, they work on the impala spindles, you need to buy brackets to mount the calipers on and use 78 -84 monte carlo calipers. I got mine from GH Grove. you'll need a dual masrer cylinder and a proportioning value. As aceuh said check out chevytalk and do a search you'll find all the info you need.
