Powered By Ford Thread
Discussion in 'The Hokey Ass Message Board' started by FordMaverickFanatic, Mar 5, 2010.
  1. FordMaverickFanatic
    FordMaverickFanatic
    from Taylor, MI
    I hope you all know I didn't just mean your cars, If it's got a Ford motor put 'er up here.
    Suprised nobody metioned this.
    I forgot who, but someone used to race a chopped Willys with a 59' Edsel motor in it.
  2. Ok, well I've also got this in the works. A Y-block powered FED. :D
  3. turdytoo
    turdytoo
    Here's my '32 3w project with a carbureted 4.6 4 cam.
  4. Stone
    Stone
    The Yellow Brick and the FED are awesome.
  5. T tyme
    T tyme
    all my fords have fords in them
  6. The Cleveland is not a "big block".
    Thank you 58custom, for that concise and correct Cleveland clarification. That "big block" moniker always bothered me too.:D:D:D:D
  7. SHRUM
    SHRUM
    My 56
  8. a40lover
    a40lover
    Sounds like the solinoid is wired wrong.:confused:
  9. 58custom
    58custom
    But I made a mistake. I failed to preface my comments by p***ing on to Bossy that he has one very fine Falcon. Looks like he modified the front end and got rid of the shock towers. Looks amazing, and I'd like to know more about it and the engine.
  10. 58custom
    58custom
    My '58. Got a 460 in it now but I'm putting the FE and all of the old drag stuff back in.
  11. MERC 55
    MERC 55
    Here is mine
  12. Kiwi 4d
    Kiwi 4d
    286 cu in 1939 merc flathead
  13. hombres ruin
    hombres ruin
    the drool factor is amazing,nice work.
  14. joee
    joee
    here's my 32 with a 460...........
  15. popbreed
    popbreed
    Here is my 56 powered by 312 Y, 3 spd OD. Been "on the road" since 1999. Also have a 64 SWB F100 still Y block powered!
  16. dirtbag13
    dirtbag13
    my 428 cobra jet dual quad motor and toploader 4 speed that was in my last car !
  17. T.W.Dustin
    T.W.Dustin
  18. Left Turn
    Left Turn
    from Omaha, NE
    Duece fordors and 460's kick major ***... That's a sweet build!!
  19. hombres ruin
    hombres ruin
    This ride is awesome,,,very nice.
  20. Dave Flanders
    Dave Flanders
    Here's my 41 - 2.3 with a turbo and a T5. We get 30+ mpg at 75 and have run 13.50's with basically a stock motor. Just got it back on the road after using it to hold down the garage floor for the past 4 years.
  21. Gasser57
    Gasser57
    Great Thread!
    The 429 SCJ in my Custom, not the prettiest engine, but you sure can stroke them!
    My all-time favorit is the Y-block. My 57 F-100 had a few over the years, this was the fastest.
  22. Glad to finally see some more Ys other than mine show up. :p
  23. HealeyRick
    HealeyRick
    from Mass.
    This (once dressed to look like a Cobra 289)
    Is going here:
    which is the engine compartment of this:
  24. bluestang67
    bluestang67
    Work in progress a 5.0 HO with a AOD now took out the 5 sp for another project , also has a 8 inch rear end .
    The 351 W will have the T-5 and 9 inch going in this soon .
  25. MP&C
    MP&C
    Does a Lincoln Y count?
  26. T.W.Dustin
    T.W.Dustin
  27. 39 All Ford
    39 All Ford
    from Benton AR
    ANOTHER Lincoln motor, too damn cool to be excluded from the "Ford thread" !
    From my 55 Lincoln
    My Daughters Falcon
    Son's Falcon
    Other Son's Mustang
    My 39
  28. 56fordpickemup
    56fordpickemup
    from So cal
    No pics but have a 429 in my 56 ford pickup build
  29. joee
    joee
    thanks.......my 1st drive yesterday,i put her in a snow bank !!!!
  30. thommoina33
    thommoina33
    Alliance Member
    from australia
    here's my old ford powered f.e.d, blown alky cleveland, nascar block,4v iron heads,block grout filled,je blower slugs,roller cam,bug injector and 110 pump,sitting in an old mild steel rigid 150'' frame,made some pretty exciting p***es,low 8's high 7's at 180 mph.this was back in the mid to late 90's, engine expired when the crank broke in 2 (could only aford a 4mab crank).i have great memories of pulling the front wheels up at 1/2 track. (sorry about pic,i could only scan one of my old poleroids).
