Bonneville styled 1932 tudor build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Oct 17, 2009.
  1. Uptown83
    Uptown83
    My favorite thread :)
  2. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Killer build. Look forward to the finished photoz.
  3. paco
    paco
    from Atlanta
    Great build ...... I'm in.
    Paco
  4. Hot Turkey
    Hot Turkey
    I'd like to hang out in your shop!
  5. irace2win41
    irace2win41
    This is one of my favorite sedans of all time. Love the louvers......
  6. Patrick46
    Patrick46
    Hate to say this HT...but I doubt few, if anyone, 'hangs out' at his shop.
    There looks like alotta work being done there, and anyone just 'hangin', would be run off for being in the way.
    I don't mind it when someone wants to check the progress on onna my projects....but then I gotta get back to work, so it doesn't take me long before I 'run 'em out'........(or hand them a broom! :rolleyes:)
    btw.........this is such a tough car!!!
  7. Hot Turkey
    Hot Turkey
    Yes true, but when I hang out in someones shop it's to learn. Looks like I could learn volumes from him. I always offer my labor to compensate for my hindrance.
  8. VAPHEAD
    VAPHEAD
    Nothing on the dash yet?
    Peanut ****er and jelly ? :)
  9. Salt Flats Speed Shop
    from Utah
    I should be getting an original speedometer this week. I have the tunnel in the car currently. Looks great! Thanks.
    Just trying to get the sheet metal all finished so that I can do a bare metal photo shoot.
  10. electron
    electron
    Car looks awesome. When you started I wasn't sure if you'd make speedweek. With your progress it looks like you'll make it without any problems.
  11. Pinstriper40
    Pinstriper40
    Looks *****in'! I haven't checked the thread for a while... Looks like the louvering was a fun job!
  12. Crafty B
    Crafty B
    super work man!!!
    Crafty
  13. thunderbirdesq
    thunderbirdesq
  14. Salt Flats Speed Shop
    from Utah
    It seems like forever since I have had anything to post new on the car. Ive been slaving away on mounting the steering. What a job!
    The box has two mounts, one on the cowl, and then one that spans across the transmission and the firewall. I made a brace that bolts to the frame and comes over the trans that holds the bottom.
    Then the column is held using a 40' truck drop and shaft. I made a bracket that the shaft slips inside that bolts to the steering box. It's all nice and strong now. Next its figuring out the pitman arm, and steering arm.
  15. willysguy
    willysguy
    from Canada
    This project just keeps getting better....Way to go Chris!
  16. Pewsplace
    Pewsplace
    The steering installation looks great. Some of them don't look safe but yours looks correct...nice and strong. I am curious, will the interior be finished with buckets and have a back seat? After racing you may want to put this car on the street as it has the look. Keep pushing the envelope.
  17. I liek the execution, dont dig the fake patina. Your work is better than many twice your age. Paint the damn thing Washington Blue and let it age gracefully!
  18. -Brent-
    -Brent-
    I agree. It'll get there soon enough, for sure.
  19. Damn good looking car!
  20. Salt Flats Speed Shop
    from Utah
    I'm getting some original seats so it will have the two buckets and the bench seat in the back. Other than that the rest of the interior will be striped down bare. You will see the back side of all the metal and all the wood. You'll look right through the roof and through the louvers.
  21. bluesman
    bluesman
    from spring tx
    man oh man!!!that car is bicthin great build man, very nice metal work!!!!
  22. Salt Flats Speed Shop
    from Utah
    Just getting all the rest of the sheet metal all ****oned up, sanding it all uniform. Once I can get all the exterior of the car finished im going to do a bare metal photo shoot. So I need to finished up the headlight bar.
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
  24. langy
    langy
    looking very smart.
  25. Hot Turkey
    Hot Turkey
    Man, I love it!!
  26. Pinstriper40
    Pinstriper40
    Looks great! I really like the way you set up the steering with the hoop over the transmission. Are you going to put any holes in that piece at all?
  27. pompadour
    pompadour
    Looks good...How far out of the cowl does the box stick out? Aso what pedals are you using?
  28. Salt Flats Speed Shop
    from Utah
    It will be under the trans tunnel so I wont worry about putting holes in it. I want to put as much wood floor back in as I can. I might have to be creative in the front area.
  29. Master of None
    Master of None
    Damn I want a 32 2 door sedan!
  30. Salt Flats Speed Shop
    from Utah
    It sticks out about 3" to 4" to where the pitman arm is. I plan on mounting the tie rod on the back of the pitman arm so that's why it needs to be out that far. I will be making a blister that covers the whole unit and the arm will just stick out the bottom.
    I plan on using the ch***is engineering clutch and brake pedals. They require some modification for the clutch pedal, but they will directly bolt into the center cross-member in the car.
