Engine Turning, A new Spin (Waa Waaahh)
Discussion in 'The Hokey Ass Message Board' started by cactus1, Mar 9, 2010.
  1. FlamedChevy
    FlamedChevy
    Very nice job on the panel...I love engine turned items. I have the gauge panel in my wife's 37 chevy and the glove box door turned.
    We use elevator bolts for many things in auto manufacturing ( Hard stops on small machines, Proxy switch accuators and you can put a rubber pad on for rough locators).
  2. Ha! Sorry. I'm pretty, but dumb. Ron Howard's brother right?:rolleyes:
  3. Chaz
    Chaz
  4. Those bolts are also used to bolt the hinges on wood garage door panels...
  5. Moonglow2
    Moonglow2
    When I did mine I secured my metal sheet to a board and carefully laid out the spacing with a fine point pen (on the wood). Then turning the board on edge I took a large knife and lightly whacked the edge of the board at each mark to put a small crease every swirl width. Then I took a piece of 5/8" thick x 1" board and whacked a groove near the middle of it and then , turning the 1" board on edge, tacked it to a piece of plywood base. I found the smallest diameter of finishing nail I had and nailed it in the upright 1" board right in the knifed groove. The object is to recess the nail enough to leave only a small amount of it above the surface.
    With the nailed guide clamped securely to the drill press and centered behind the burnishing tool I took the first board containing the metal workpiece and aligned the far left knife cut with the nailed guide.
    As I finished the first swirl, I simply slid it to the next knife groove and repeated the next swirl. After completing the first row of swirls you then have to reposition and measure the clamped nail guide further away from the burnishing tool and start the next row.
    If you want to stagger alternate rows adjust left or right of the first row. It's tedious work especially if you do small diameter swirls like I did but the results are worth it. I used 1/2" cratex rods filed down to 3/8" diameter.
  6. SinisterCustom
    SinisterCustom
    Simple tech is always the best....
    Nice work.
  7. scootermcrad
    scootermcrad
    Yep! Done it this way also! Works very well! Lookin' good! Shows the finished results when you're done.
  8. rusty_bits
    rusty_bits
    I used a scotch brite pad in a socket and indexed it on my milling machine, it took quite a while. I did some test patches on some s**** before doing the final parts.
  9. spot
    spot
    from usa
    Wow great idea, When i worked my way through college in a machine shop we called this swirl polishing. I did a couple dashes for friends on a CNC after work. I used a short piece of micarta (spelling?) and polishing compound. Usually did 3/8" swirls. Program the cnc, clamp the stainless down paint it with polishing compound and turn the machine loose.
    I can use this method at home. thanks for the tech!!!!
  10. -Brent-
    -Brent-
    What's the secret for keeping the rows and columns straight?
  11. rusty_bits
    rusty_bits
    On the milling machine it is easy, because you have an X,Y table all you have to do is keep track of the distance you are moving in each direction which is read right off the dials. regards,
  12. -Brent-
    -Brent-
    It looks like he's using a drill press though.
  13. mitch 36
    mitch 36
    I was thinking along those same lines except I was going to use an old valve from a 3 hp Briggs and Stratton engine and glue some 3-M scotch brite pad to it. Same principal different ptocess I guess. Thanks , Mike.
  14. rusty_bits
    rusty_bits
    Brent if you are talking about my photos, it is a small Clausing vertical knee mill.
  15. I have some rather large pieces to do, stll trying to figure out an easy/fast way to index the sheet.
  16. SinisterCustom
    SinisterCustom
    Couldn't a simple grid be laid out right on it....with a scribe? Then as the "swirls" were made, each scribe line would "disappear" from the turning process?
  17. Mark H
    Mark H
    from Scotland
    That's how I did it but using a black marker pen instead of a scribe.
    Engine Turning Stainless;
    http://www.jalopyjournal.com/forum/showthread.php?t=364114
  18. renrob5000
    renrob5000
    When doing it with the mill, using a 1" pattern, I not only overlap by half on the next row down, I index back 1/4". That way the finished pattern has the cool diagonals as well...
  19. Hey guys, thanks for all the great replies and ideas on registration of the pattern. Up until now i have only done it "by eye", but given my nature, I want something a little more uniform. I do not want it however, to loose the "hand made" flava'. I have been mulling over several methods in my head. The pegboard idea is one that sprang to mind but it is a bit limited due to the 1" spacing I think, but I could be wrong.
    As far as larger pieces for firewalls and the like are concerned, I was thinking of a radial drill press, which is usually used in furniture making. It would have a larger swing so it would be easier to get to the center of those large panels.
    A mill would be nice, but out of my budget.
  20. stude54ht
    stude54ht
    from Spokane WA
    I used peg board to index this turning on my Studebakers firewall. I needed a deeper throat than my drill press allowed so I made a long arm to hold the drill, worked out ok.
      295.8 KB
  21. rfoundit
    rfoundit
    from Kansas
  22. scootermcrad
    scootermcrad
    Could you please explain how you actually used the pegboard? Was it attached to the back and then moved around dropping the pegboard hole and the piece into a locating pin?
  23. wizzard23
    wizzard23
    I remember reading a magizine artical on this years ago (possably Rod Action). Used old time graph paper (is it still available?) for lay out and some kind of abrasive stick in a drill press to do the job. Probably not much help, but thats the best this old mind can do!:eek:
  24. garagerods
    garagerods
    from Omaha
    Great tip....I'm sure Ken is proud!
  25. storm king
    storm king
    Nice tech tip. I've been doing it that way since the early '80's, no fancy mill, just careful application of a drill press and guide bar "C" clamped to the table.
  26. i was just thinking that. i looked into engine turning a few years back but didnt get any further with it than reading about it, but i didnt have a garage either. got one now so im going to expierament.
  27. As for spacing, lots of good ideas here, but I bet a hand drawn grid is good enough; since they are round shapes, perfect alignment probably isn't necessary. I'd practice on a piece of s**** until I got the hang of it.
  28. charleyw
    charleyw
    Elevator bolts work well for F-1 running board bolts and rear fenders also.
  29. After spending the week experimenting with The elevator bolt and various abrasives I went and got a Cratex sample to play with.
    I also used the search with teh words engine+turned and got a few dozen threads. Kevin Lee had one of the best (2 actually). His outcome and mine is that the sandpaper does not work that good. Kevins thread
    http://www.jalopyjournal.com/forum/showthread.php?t=107830&highlight=engine+turning
    And another
    http://www.jalopyjournal.com/forum/showthread.php?t=107101&highlight=engine+turning
    I was working with aluminum sheet. The issues I had with various abrasives were:
    220 PSA sandpaper on elevator bolt; too hard, doesn't conform to the flat sheet to even give you a uniform circular swirl.
    220 PSA on double sided tape like Cactus used; works well, pattern is too faint and you get "ghosting" when you overlap swirls. Too much pressure and the paper slides off
    120 PSA, too co**** for Aluminum, may be better on Stainless.
    Fine Scotchbrite Gray; same issues as with 220, not course enough and wears out/balls up fast
    Medium Scotchbrite, Red; Edges too vague. I did a stainless panel in the past with this and it was small so it looked OK.
    160 Sanding Screen wrapped over the elevator bolt, too course, uneven swirls.
    As for locating the work, I talked to a machinist at my tool supply and he loaned me his Cratex to play with. His thoughts on a grid or pegboard was to clamp it solidly to the press and use the holes to locate the piece as you move it around on the board. He says it works really well.
    So, that is my humble findings. I am off to play with my 1/2" Cratex, decide on a good diameter for my dash etc. Between the dash and other parts I figure I have 40 hours worth of work ahead of me:eek:
  30. scootermcrad
    scootermcrad
    Great! Cool! Thanks! I'm anxious to try it like this. I got to thinking that if you took your time and made other hole patterns you could create different turned patterns as well. Like maybe a circular pattern. Would take a ton of time to drill all the guide holes, but if the holes were laid out with CAD first and then transfered to a piece of masonite and drilled, it would probably work pretty awesome.
    Too much thinking... sorry! :p:rolleyes:
