freeze plugs and sealer???
Discussion in 'The Hokey Ass Message Board' started by Dan, Mar 11, 2010.
  1. Dan
    Dan
    Everything you read says to use sealer when installing freeze plugs, what sealer do you use??? I've always just installed them dry???
  2. Dreddybear
    Dreddybear
    Indian Head. two bucks at any parts store, its a mol***es brownish black :)
  3. I've never used sealer. Never had one leak. I guess it couldn't hurt though.
  4. 55 dude
    55 dude
    call some local engine builders and go with their answers. i have seen blocks that were cracked in freeze plug area because they were installed using permatex. i use silicone and haven't had any issues.
  5. Jims35
    Jims35
    Never use sealer , never had one leak . Just make sure they are the correct ones and not undersize.
  6. el Scotto
    el Scotto
    from Tracy, CA
    I'm with the "nothing on the freezeplug when I install them" crowd... probably couldn't hurt 'em, but I've never done it before and never had a problem...
    49 olds likes this.
  7. Country Gent
    Country Gent
    Permatex NON-HARDNING. Old reliable. Never had a problem. Helps them install a little easier.
  8. Mr48chev
    That's what I have used for 45 years and never had a problem.
  9. bobss396
    bobss396
    Indian Head or the Permatex product mentioned here are both fine. I'll use whatever one I find first, just count myself lucky to find anything in my garage.
    Bob
    Sturges likes this.
  10. RopeSeals???
    RopeSeals???
    Aviation Permatex
  11. DerKafer
    DerKafer
    from San Diego
    Another vote for doing it dry.
  12. TagMan
    TagMan
    Me, too.
    ......and they're NOT "freeze plugs" for the 5,486,905th time. They're "CORE PLUGS", used to fill the holes used during the casting process. That's all they were designed to do - they were not meant to pop out and prevent the block from cracking because somebody forgot to add antifreeze. I've seen cracked blocks with popped out core plugs and the plugs didn't save those blocks.
  13. Dry or a little Gasgacinch.
  14. Dino
    Dino
    I use br*** plugs and The Right Stuff.
  15. 29nash
    29nash
    from colorado
    I have used a dab of paint in the distant past when installing a welch/freeze plug. Since somebody invented loc***e and it's more readily available in my tool box thats what I use. A good friend of mine don't use anything, just spits on them and drives them.:D
    What are they called? Real mechanics don't argue about the small ****.
    briggs&strattonChev likes this.
  16. rjaustin421
    rjaustin421
    I have installed probably 5,000 (not an exaggeration!!!) and have always put a light coating of silicone on them/
  17. gtnrkix
    gtnrkix
    I like it dry!
  18. ponchopowerd
    ponchopowerd
    leve it dry or if u ant to use a sealer ive used gray rtv
  19. johnnie
    johnnie
    from indiana
    Been using loc***e ever since I was taught to do it at a engine re-builder company. Never put anything on them before and never had a problem. I would call using it "insurance".
  20. GARY T.
    GARY T.
    from S.W. Pa
    Use br*** ones--NAPA has them--if not boat shop---don't need any sealer
  21. Hackerbilt
    Hackerbilt
    I've always put a dab of paint on them.
    Not spray bomb, but right out of the quart can.
    A bit of paint will also protect them a little longer from rust, so its all good!
  22. Pooch
    Pooch
    from Oklahoma
    Dry...never had a problem.
  23. Domino
    Domino
    I have installed them both ways and never had a problem. Lately I use the gasket shellac that smells horrible. I do always use the br*** plugs when I can find them.
  24. 56oldsDarrin
    56oldsDarrin
    that purple stringy stiff that comes in the little round can...that stuff.
  25. 57JoeFoMoPar
    57JoeFoMoPar
    Add another one. It would probably be fine for me dry, but for $2 why take the chance?
  26. tommy
    tommy
    I guess it all depends on what you are working on. This is a Studebaker that takes the domed washer like kind. Yeah I wire brushed 'em but the sealing surface still wasn't perfect. I used silicone for the imperfections. Unless it's a macho thing I don't see why a little sealer is a bad idea. It's like insurance to me. I'm a wuss I use sealer.:D I had one pop out when I first got it running. I wasn't sure how much hammering was required to expand the disk. I put it back in and and gave it a good whack. The rest worked fine. I hate seeing an engine with "blue goo" all over it but in moderation I see nothing wrong with it. JMHO
  27. Medium strength Loc***e >>>>.
