How Do I Remove STRIPE painted on my car?
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Mar 11, 2010.
  1. fordstandard
    fordstandard
    Guys-- I bought a car that has a Painted "stripes that I'd love to remove from the car !
    QUESTION ; How can i do it without screwing up the cars paint
    AS YOU GUYS REQUESTED-- I JUST UPLOADED PICTURES
  2. BuiltFerComfort
    BuiltFerComfort
    I'm not a pro nor a good amateur, just knew some guys in high school into cars, so listen to other people before me.
    I saw it done successfully ONCE and screwed up a couple more times. The one successful time the guy put masking tape down the outside of the stripe, and used rubbing compound and did it entirely by hand. The failures all involved power tools or solvents.
  3. Kevinsrodshop
    Kevinsrodshop
    Any chance the stripe is under a clearcoat? If its painted on you might be able to lay some tape on each side of the stripe and sand and repaint the stripe but it will never match the original color.
  4. ponchopowerd
    ponchopowerd
    goo off works perty good you can get it any store in the cleaning isle
  5. It all depends if it's been cleared over. If not you can probably wet sand it with 2000 grit and buff it off. If it is under the clear the only option is to repaint it a color you like or shoot the whole panel.
  6. only problem is if its older paint job the color under the stripe most likley wont match the color of the rest of the car of atleast thats what I've noticed when guys have taken off stripes
  7. Pontiacres Ranch
    Pontiacres Ranch
    Easy Off Oven cleaner will remove 1 shot lettering & Pinstriping. Ive taken factory stripes off of cars up through the 90s with it. I have a buddy who took lettering off of a 70 pontiac race car with it. Do a test patch before you try the main surfaces. You will still see the stripe after it is removed, but once its wet sanded and buffed, it will be gone.
  8. CyaNide
    CyaNide
    from Texas
    Pics would help too. If no clear and if the original is not laquer paint, I would try laquer thinner first.
    CN
  9. Sunshine14
    Sunshine14
    Any pics of the car
  10. Sunshine14
    Sunshine14
  11. T. Scott
    T. Scott
    i agree i have used easy off let it set for like 5 mins and strat in with a healthy amount of elbow grease ive used micro compond leveler also which is like liquid sand paper and i ve also used 1500 grit wet dry sand paper to a 2000 grit an so on but this will require buffing after ... but the main thing to do with any of these to us caution it can go wrong and if its under clear coat then your going to have to wet sand and reshoot the clear then buff
    p.s. ive done all of these and good luck
  12. Pontiacres Ranch
    Pontiacres Ranch
    Yeah....What T.Scott said about the elbow Grease....forgot that part.....
  13. fordstandard
    fordstandard
    Here are pictures of my car
    The Yellow and Orange Stripes are what I want to remove!
    Hope this helps to better descripe what i have
  14. fordstandard
    fordstandard
  15. my pinstriper friend uses a razor blade and swears by it. although he did say you need to be very very carefull. obviously.
  16. Pontiacres Ranch
    Pontiacres Ranch
    Id try the easy off......Like T.Scott says, under 5 min.....rub Hard, and re apply.....wash it down with a wet rag once in a while.....
  17. oldebob
    oldebob
    from Spokane WA
    If you just swipe the corners of the blade on concrete before you use it it is a lot more forgiving.
  18. 100% Matt
    100% Matt
    Oven Cleaner.....for real
  19. philly the greek
    philly the greek
    from so . cal.
    I just removed some existing pinstriping and then re-striped it in a different color . I wet sanded w/ 1200, then 2000, followed by a buffer and compound then a foam pad with some machine glaze . No problems at all .
  20. BEAR
    BEAR
    i just did the same thing ... but if its been on there to long you will see it in the clear....
  21. pasadenahotrod
    pasadenahotrod
    from Texas
    "Flathead Ford V8, the original HEMI"...Your car has an ARDUN under the hood and your don't want to brag?
  22. Brandy
    Brandy
    from Texas
    I used a rubber sanding drum on a boat I had. I picked it up from an automotive paint store....looked like a round, yellow eraser disc that fit into my drill on a chuck.........turned it on and hit that gay *** striping without ruining the paint below.
    Bada bing.
  23. Dan Hay
    Dan Hay
    Take off the lettering while you're at it.
  24. studhud
    studhud
    Easy off works great mask both sides of the stripe it can screw up the paint in left too long you might try a pumis stone. Automotive paint supply store will have them for removing runs. It's a hard stone not a clay bar just be careful with it on panels with alot of curve
    Dave Hitch
  25. fordstandard
    fordstandard
    Man-you guys are the best !
    That's what makes this site awesome--the help and knowledge you all offer is very appreciated
    *P.S yes i'll remove lettering as well //i do like the blue paint dude.
  26. 1927 Death Trap
    1927 Death Trap
    from CT
    Easy Off Oven Cleaner works great if: The stripes are not under the clear and/or it's not laquer!!!! It will totaly screw it up if it is.
  27. zman
    zman
    from Garner, NC
    yep, that's pretty silly.
  28. Kensey
    Kensey
    from Pittsburgh
    Enamel Reducer will work fine. Use a terry cloth rag, has some tooth to it. If it's old one shot, than it has lead in it. REALLY hard to remove. Newer one shot is no where near as tuff. Good luck.
  29. fordstandard
    fordstandard
  30. CedarSpeed
    CedarSpeed
    a fellow told me that wd-40 will work he had pink stripes on a mini truck in the late 80's said it worked 4 him, saw the truck later it looked good might try it?
