english wheel pictures
Discussion in 'The Hokey Ass Message Board' started by r600, Mar 14, 2010.
  1. r600
    r600
    hi ,i want to make a english wheel but before i start i want to see pictures from anyone thats made one and pick what i like so please post your picture of your english wheel,thanks adrian
  2. willymakeit
    willymakeit
    I would do a search at metalmeet.com and some of the other metal sites. Lots of good info.
  3. emiliedk
    emiliedk
    from denmark
    heres mine just finnished his week!
    -palle
    Okie Pete likes this.
  4. vendettaautofab
    vendettaautofab
    Well no ****... thats nice! Hows it work?
    BAILEIGH INC likes this.
  5. studhud
    studhud
    Wow that is pretty:) How thick is the plate on the sides???
    Dave Hitch
  6. emiliedk
    emiliedk
    from denmark
    thanks! well i am in no way an expert...but it seems like it works perfect. now its only practicing
    the sides are 6 mm...not sure how much that is in inches!
    -palle
  7. Jay Rush
    Jay Rush
    That is a work of art. Outstanding
  8. captainjunk#2
    captainjunk#2
    jay Rush is correct that wheel is a beautiful piece of craftsmanship , a work of art ,
  9. Stefan T
    Stefan T
    from Sweden
    Her's a pic of my english wheel and it made with 3 mm sides
    3mm approx. 1/8" and 6mm is approx 1/4"
    Sorry the pics is not taken for show the wheel
    it works well it have 7 diffrent under wheels and i have made it togher with a frend that have one too
  10. heatnbeat
    heatnbeat
    from Madera,Ca.
    Here is one I just finished. and one I built 3 years ago(orange 42" deep)
    5x5x3/8 tubing
    30 in deep
    doubled the back bone
    upper adjuster with HF upper wheel(modified and trued)
    bolt on bottom arm
    retractable lower casters
  11. 48stude
    48stude
    Here is a pic of mine. Bill
  12. r600
    r600
    like the other boys said sweet english wheel-keep up the great work manship cheers adrian
  13. spobanz
    spobanz
    Cool thread! A friend, industrial engineer, gave me a bearing once from a HUGE shredder. I think they would be perfect for building english wheel's - very high quality steel. I'll try to find out more and re-post.
  14. michael037
    michael037
    Bill
    What size steel did you use in your frame.
    Michael
  15. That is beutiful.
  16. carbuilder
    carbuilder
    Here is a picture of 1 of the 4 I have in my shop Danny.
  17. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  18. KrisKustomPaint
    KrisKustomPaint
    Old bandsaw frames are great for making cool stuff. Did anyone see that killer Louvre press that was made from a bandsaw frame?
  19. inkmunky
    inkmunky
    That was Kiwi Kev's and it's incredible to just look at.
  20. roddinron
    roddinron
    Damn,Emiliedk, that's nice! I'd have to keep that in my living room!
  21. Here is my latest personal machine:
    It has a 62" throat and is way bigger than anyone needs. I just did it because I could. My previous personal machine was a 48" throat.
    It was one of two I built like this. Dutch Comstock has the other one. I really liked it and planned to keep it forever but a client bought it for a sculpture made from 1/4" aluminum.
    The new one is the replacement and it is the best wheel I've ever used. It has variable stiffness thanks to some Belleview washers in the adjuster. Soft when you want it soft, stiffer than a bridegrooms pecker on his wedding night when you want it stiff. The build diary is on AllMetalShaping.com
    There is an Ewheel Building Seminar on MetalMeet.com that I wrote many years ago. I had previously removed it after some problems with MetalMeet but decided to leave it up after MetalMeet restored an old backup. You have to join to see it. Look in the Library.
    Here is a photo of the most popular machine we make, the 26F. It's been widely cloned and is a very nice machine. The tubing is 6x3x1/4.
    It's coated with LineX but that's just because we want to make the finish industrial. The sheet metal doesn't care.
    One word of advice regardless of what you build. If you're rollers are not true (ie HF or similar), don't build a stiff frame. The out of round rollers with a stiff frame will make lumps in your panels as they wop, wop, wop around.
  22. 48stude
    48stude
    Hi Michael, My frame is all 1/4" wall , the main part of the frame consist of 3 x 3" and 3 x 4" tube that I welded together making it 3 x 7" overall. The rest is 3 x 3" x 1/4". Hope this helps Bill
  23. emiliedk
    emiliedk
    from denmark
    that could be arranged ! maybe i should call it 'the great dane' ha ha
    -palle
  24. holeshot
    holeshot
    from Waxahachie
    R600...GEEZ i thaught the english wheel was something the brit's used to tortue the french! HA!...POP.
  25. hotrod1940
    hotrod1940
    The is a cool looking wheel for sure. Looks like a modern piece of art.
  26. gearhead78
    gearhead78
    from Dallas TX
    I didn't make it but sometimes things just work out right. Its solid cast iron and weighs 1000 lbs put together. If I told you what I have in it you would get sick to your stomach and I will keep my mouth shut. :p
  27. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    HERES MY WHEEL AND PULLMAX
  28. JustplainJ
    JustplainJ
    from so.cal.
    some of my old ones.....
  29. r600
    r600
    does anyone have anymore pictures of there english wheels we have seen some great wheels,does anyone know where to get anvils cheap not nastie,cheers adrian
  30. image.jpeg This is one I just finished . Made out of 1/4 plate
