Hot Rods Rear ends for Model A? What ones are you using?
Discussion in 'The Hokey Ass Message Board' started by poweredbylincoln, Mar 13, 2010.
  1. poweredbylincoln
    poweredbylincoln
    Hello hambers I wanted to say thank you for your help on my past threads and I wanted to start a new thread and ask what rear ends are you running in your model a's?
    I have a 30/31 coupe and a 30/31 pu coupe has mild 302 that i plan to pump up before to long and pu has a 368 lincoln y block
    both are fenderless...maybe fenders later....
    I wanted to ask what rear ends you are running?and from what year/make/model donor vehicle you got them out of =)
    and what do they measure backing to backing and drum face to drum face?
    and what year and make model a do you have
    any help would be appreciated and have a great day
    thanks hamb
  2. crider
    crider
    I'm using a 9" ford from a 57 sunliner in my 30 sedan. Fit perfect with fenders.
  3. 17dracing
    17dracing
    from Indiana
    I'm running a 31 spline axle, 9" ford , out of a 1978 ford truck in my 28 model A sedan . I don't think I could have asked for a better fit . I got about a 1 1/2" space on either side of the body . And she lays low !! About 58" or 59" backing plate to backing plate .With L-78 x15 mounted on mid 50's caddy wheels .
  4. 562roadster
    562roadster
    I'm running a 9" off a '58 Ford Ranch wagon. It fits with and without fenders.
  5. AZ29
    AZ29
    from Arizona
    '48 Ford F1 dana/****er model 41. Geared pretty low,but running 29in tall rear tires.
  6. fastrnu
    fastrnu
    from shelton,wa
    My 1930 roadster is a falcon 8", my 1930 5 window had a 68 mustang 8", the 1929 truck we used an after market 33 spline spooled 9" salvaged from a wrecked 73 chevy truck, and lastly (yes its a TT) we used a 28 spline 9" from a late 60's torino/failane with 78 Toyota 1 piece duallys
  7. I'm running a 9" out of a cougar.
  8. lorodz
    lorodz
    1946 ford banjo rear with open drive line...
  9. baspinall
    baspinall
    from SE PA
    8" from a late 60's comet here.
  10. Abone29
    Abone29
    Narrowed 31 spline 9" out of a Full size Bronco.
  11. TERPU
    TERPU
    1936 Ford Banjo with 46-48 Juice brakes on it.
    Tim
  12. bab59
    bab59
    57 Chevy rear
  13. Krash
    Krash
    from Cleveland
    Same here.....mine's out of a 78' Ford Truck. 59" backing plate to backing plate. I have mine in a 30' Model A Tudor. I've got about 1 1/2" space on either side. It's pretty low. I have 40 Merc. wheels (5" wide) with Tall *** Firestone bias plias. Fits perfect without any modifications. It has a heavy duty housing. 5 on 5 1/2 bolt pattern. I paid $100 bucks for it.
  14. bobscogin
    bobscogin
    1990 Ford Ranger pickup in a fendered '29 rpu. 56" wide, wheel mounting surface to wheel mounting surface.
    Bob
  15. thunderbirdesq
    thunderbirdesq
    Halibrand/'40 Ford under a 31 A roadster...(eventually...)
  16. scrap metal 48
    scrap metal 48
    S10 with 1" adapters to run 5 1/2" bolt pattern.......
  17. fordrat31
    fordrat31
    from Palmer, MA
    Im running an 8 inch! In my opinion they are prefect for model A's. Also think about it, you dont really want a spool or locker with a model A. They are so light, it would be very dangerous when you let the smoke out of the rears!
  18. millrat
    millrat
    from Central MA
    I have a '29 Tudor Sedan. I'm running an 8.8 from a '92 Mustang and it's been converted to 5 lugs (formerly 4 lugs).
  19. heatnbeat
    heatnbeat
    from Madera,Ca.
    I used a Mavrick 5 lug 8" fit perfect
  20. Doug B
    Doug B
    I'm using a first generation Bronco 9" , running without fenders
  21. vegas
    vegas
    I'm using a 1979 Ford LTD wagon 8.5 rear axle, and I was able to put in a Mustang 8.8 locker and 3.27 gears into. it clears the body sides just fine on a channeled car (no fenders,obviously)
  22. fastrnu
    fastrnu
    from shelton,wa
    i heard all the stories! your rear end will come around in the rain. (Cool) It will plow straight ahead through corners! It'll tear the rear tires up blah, blah, blah.
    i ran spool in my 29 for over 2 years. No problems. 2180lbs with my big *** in it. i had everything on the back from 15" wide tires to skinny bias ply silvertowns. drove it 6o miles one day in a total down pour in a cancer run for an ABATE brother. Rearend was always right there behind me. never did p*** me up.
    Heres a shot at the Shelton drags. Held pretty straight for me even after the smoke let up.
    Question would be how do you get smoke out of the rears without a locker /spool hmmm
    Bottom line: ya drive it like what it is.
  23. Mark H
    Mark H
    from Scotland
    I'm using an 8 inch rear from a '65 Mustang.Can't recall the width,but it's pretty much perfect for an 'A'.Unfortunately,I've had to use adaptors to get a 5 on 5 1/2 bolt pattern.
    Mark
  24. ROADSTERJEFF
    ROADSTERJEFF
    I have a S10 rear end with 7 inch wheels. It is tad to wide. I plan trying 15x6 steel wheels with a four inch back space.
  25. modelacitizen
    modelacitizen
    I've an 8" open diff from a 70 mustang. 2.79:1 It's sitting behind a 430hp Pontaic 400 and a Th400 trans. Guess what the weak link is?
  26. Slorolnlow
    Slorolnlow
    from Florida
    Got a '58 Fairlane 9" in my '31 coupe.51" between the backing plates,56" flange width.It's fenderless and has some good meats on it,fits well.We put a 8" in my pops '31 full fendered roadster.49" backing plate to backing plate and 54" flange width out of a '70's Maverick.These rears are getting scarce and pricey though.I have measured 8.8's out of Ranger pick-ups to be 52" between the plates.Good width,funky driveshaft flange plate however.
  27. resqd37Zep
    resqd37Zep
    from Nor Cal
    No longer have an A but nothing looks better than a quickchange out back.
  28. Slorolnlow
    Slorolnlow
    from Florida
  29. poweredbylincoln
    poweredbylincoln
    Man =) Thank you guys...I appreciate this very much...everyone's welcome to join n let us know what donor rear end you are running and what year make model u got it out of
    width backing to backing, flange to flange n what model a you have it in and fenders or no fenders
    thank you guys again
    By the way for the guys that used 78 ford truck rear ends, did you get the 9'' not the dana rear? and out of a f100,f150 not an f250?
    and would a 73-79 pickup have the same width rear end?
    thank you hambers
  30. 73-86 ford f150 had 65.25" width on 9"
