Threaded Upright Sleeve?
Discussion in 'The Hokey Ass Message Board' started by MCCrawlers, Mar 17, 2010.
  1. MCCrawlers
    MCCrawlers
    from Utah
    I have searched but I can't find any info on the parts I am looking for. That may be because I don't know the technical name for the part.
    I am putting dropped uprights in my 51 poncho. I removed my factory uprights, and removed the threaded sleeve that goes in the upright. I believe the sleeves are for setting alignment camber etc... The lower sleeve on both sides of the vehicle were stripped where they thread into the upright. Since they are stripped, I need new ones.
    What is the technical name for these inserts?
    Where can a person buy new ones?
    Any help is appreciated.
  2. myride2
    myride2
    from canada
    if u are talking the upper control arms,i have an manuel that calls those, UPPER PIVOT PIN AND ECCENTRIC BUSHINGS, hope this helps u out
  3. myride2
    myride2
    from canada
    forgot to say thats for all 49 to 52 pontiacs, the lower control arms are called, LOWER PIVOT PIN AND BUSHING
  4. MCCrawlers
    MCCrawlers
    from Utah
    The sleeves I am referring to are on the upright that the spindle mounts too. The names you listed sound like they are the pins and bushings that mount the control arms to the ch***is. But I could be wrong. Anybody else want to confirm?
  5. myride2
    myride2
    from canada
    u must be refering to the steering knuckle , lower pivot bolt and threaded bushing
    upper pivot pin and threaded bushing is all the manuel calls them. and are the same for years 37 to 52
  6. 24riverview
    24riverview
    Are you sure they are stripped? The threads on the outside of those bushings are very shallow, look more like a ripple going across them.
  7. MCCrawlers
    MCCrawlers
    from Utah
    That sounds like it could be the correct name. Are any companies selling new bushings?
    I will double check them tonight when I get home, but I seem to remember one of the threaded bushings wobbling inside the upright when I was trying to remove it. Thanks for the info.
  8. 24riverview
    24riverview
  9. MCCrawlers
    MCCrawlers
    from Utah
    24riverview, thanks for the link. That looks similar to the one I need. I will give Kanter a call. Thanks again for your help.
