PCV install
Discussion in 'The Hokey Ass Message Board' started by fisher, Mar 17, 2010.
  1. fisher
    fisher
    OK I posted this before without one response. I'll try to state it another way. I have done the searches and know how to install the PCV but have some questions. First I have a 1954 235 Chevy six equipped with Fenton dual intake, dual Rochester B's, and a fuel pump w/o auxilary vacuum. If I tee into the intake vacuum port that I currently have going to the vacuum wipers will this effect the performance of the wipers? Could I plumb into the vacuum port on one of the carbs instead? Will I get enough vacuum at the carb (smaller connection than the intake). I currently only have one carb connected to the distributor advance, the other is capped off. Any advise?
  2. 325w
    325w
    The cam causes the lack of vac. if it his a thumper. You should be Ok taking the vac either place. Use your vac. gauge and check to see which has the most vac, Use the one with the most. IMHO
  3. mikeco
    mikeco
    from virginia
    I believe you could run it off the carb but why do you want a PCV? Just curious since it didn't originally have one.
  4. GREASEMONKEY72
    GREASEMONKEY72
    mine connects to the base plate of the carb
  5. fisher
    fisher
    I want the PCV so that it will draw the gases out of the block even at idle and slow speeds. The draft tube only works at a fair speed. I'm hoping it will stop the build up of oil film in my engine compartment. Engine is in good condition but does have a certain amount of blow by.
  6. mikeco
    mikeco
    from virginia
    Figured you had a reason thanks for the answer!
