can i use a wood band saw to cut metal?
Discussion in 'The Hokey Ass Message Board' started by forsakenfew, Dec 23, 2004.
  1. forsakenfew
    forsakenfew
    from seattle
    i know i can't with a wood saw blade, but what if i use a blade for steel? or do wood band saws run at too fast a rate? i really want to get a saw, and thought this would be and easier cheaper way.
  2. 12pack
    12pack
    just change to a metal blade.watch the fingers cuts 16gauge metal real easy.we have one in the sheet metal shop at work used every day.
  3. yes, you can....but you have to put in a metal blade , and SLOW the speed down...your wood bandsaw probabilly has a speed of 3000 feet per minute...you would need to slow it to 150-300 feet per minute
    you would have to adapt some sort jackshaft/pulleys/speed reducer gearbox, etc,.to get to the right speed
  4. jalopy43
    jalopy43
    Just be carefull when you weld wood,its easy to burn
  5. BigJim394
    BigJim394
    For some of the Sears Craftsman band saws they sell a gear reduction device to slow down the speed so that it is easier to use it to cut metal (with a metal blade abviously).
  6. bigfive
    bigfive
    from south L.A.
    this old man i know has a meat ban saw that he uses for metal. got from an old butcher or something. its bad ***. i need one of those.
    LilBlue82 likes this.
  7. cabriolethiboy
    cabriolethiboy
    A long time ago I had a meat saw that I changed over to cut metal. I used a Crosley (I think) transmission to slow the speed down. Worked pretty good.
  8. Chaz
    Chaz
    For thin guage,(up to 20) just change the blade to metalcutting. After that, you better slow down the blade speed a lot.
  9. JOECOOL
    JOECOOL
    You can weld wood OK though, you need Hickory rod and use Peanut ****er for flux! [​IMG]
  10. whizzerick
    whizzerick
    [ QUOTE ]
    [/ QUOTE ]
    LOL! [​IMG]
    lawman likes this.
  11. flt-blk
    flt-blk
    from IL
    And don't forget to clear ALL the wood dust and shavings
    out of the housing otherwise they may ignite. [​IMG]
    clem and lawman like this.
  12. forsakenfew
    forsakenfew
    from seattle
    thanks for the input guys. i know i'd have to change blades, and figured i'd have to figure out how to slow the ****er way down. i need to be able to cut some fairly thick plate.(3/16 - 1/4)
    sounds like i should probably just track down a saw designed for metal.
    where have you all found yours, and what did you pay for em?
  13. Flatdog
    Flatdog
    I have tryed and did not work out well. Could not get blade speed slow enought. Best solution? Can you say Miwaukee porta-band,it kicks ***.
  14. Busted Knuckles
    Busted Knuckles
    Just make sure its really clean
  15. J Man
    J Man
    from Angola, IN
    Does anyone know of an actual metal band saw, if so who makes it. Or is slowing down a wood one the only option?
  16. Unkl Ian
    Unkl Ian
    I think General still makes a metal cutting band saw.
    Grizzly might have one.
    Most are industrial machines,and priced accordingly.
  17. scoop
    scoop
    Could you change one of the pulley sizes to slow it down enough?
  18. Digger_Dave
    Digger_Dave
    Ian and Flatdog said it best; "If your going to cut steel, use the right tool."
    If your going to do a lot of cutting (steel) consider a "metal bandsaw" type cut-off saw that allows the blade ***embly to stand vertically and be used for cutting odd shapes.
    Wood bandsaws run at too high a speed. Even just changing to a metal cutting blades will eat blades up fast if your cutting anything thicker than 20 ga. aluminum.
    (but then again I sell bandsaw blades [​IMG] )
  19. Digger_Dave
    Digger_Dave
    [ QUOTE ]
    [/ QUOTE ]
    You need to drop from 3600 RPM to 1800 RPM OR LESS (blade speed equates to thickness, hardness and feed speed)
    Short of an industrial speed reducer you couldn't fit enough reducer pullies under the bandsaw. (the speed reducers are worth more than the bandsaw)
    Sell a lot of metal bandsaws after people have played around trying to get a wood bandsaw to work!!
  20. Mart
    Mart
    I might be out on my own on this, but angle grinders and discs are quite cheap these days, I have not used my metal band saw for quite a while. Just use the grinder. I spose I'd use it if fabricating a frame or something, but just for hacking out little brackets etc, the grinder is quicker and simpler.
    Mart.
  21. Automotive Stud
    Automotive Stud
    It would also depend on how much power you have. I bought a wood bandsaw a couple years ago, a 14 incher. I got the biggest motor available, I think it's 1 1/2 HP, so I could use it for metal. You need the power to back it up too.
    Before I had this I made an aluminum 3" thick master cylinder spacer. I bought a metal blade and used my uncle's wood bandsaw. I needed to go really slow and stop alot to let it cool, and kept a bucket of water handy. It took a while but it came out good.
  22. river1
    river1
    i save this pic from somewhere of a wood saw conversion.
    later jim
  23. Droptank
    Droptank
    My shopsmith tool has a variable speed pully on it and is slow enough, but I haven't been able to find a metal cutting blade for it yet. Anybody know a source?
    42merc likes this.
  24. banzaitoyota
    banzaitoyota
  25. Ragtop
    Ragtop
    Try to find a "BI-METAL" blade. They're worth the extra cost.
  26. Brad54
    Brad54
    from Atl Ga
    I've wondered about this, too--I think I remember the guys at Sears (their tool buyers, not the chimps behind the counter) telling me the metal saws go 23 or 33 percent slower...I don't exactly remember the numbers. Sears does sell a two-speed bandsaw for wood and metal.
    However, I agree with changing the pulleys--I'm tired, so I don't remember which way it would have to go, but if you change the pulley on both the motor shaft and the saw wheel, it'd slow it down. A smaller wheel on the motor, and a much larger wheel on the saw?
    I know the math is out there. Again, I'm tired, but I think if you took the RPM of the motor and figured the diameter of the drive pulley off the motor shaft, and then figured the diameter of the pulley on the bandsaw wheel, that'd get you started. Knowing the FPS of the saw currently would also be a good number to know.
    Or, look in a Sears catalog and see what pulleys are on that two-speed saw.
    -Brad
  27. J Man
    J Man
    from Angola, IN
    [ QUOTE ]
    [/ QUOTE ]
    Who sells these two brands? I don't remember seeing them at Lowes or the Depot.
  28. zman
    zman
    from Garner, NC
  29. banzaitoyota
    banzaitoyota
  30. mule
    mule
    get a metal blade, no probs, don't go to thick with the metal
