Projects Drug this home today - literally
Discussion in 'The Hokey Ass Message Board' started by Undercover Customs, Mar 20, 2010.
  1. Undercover Customs
    Undercover Customs
    I have been bugging the next door neighbor for 3 years to sell me their 64 Rambler that has been sitting in their yard for 10 years. It's all stock, 2 owner car from eastern Washington. Well, they knocked on my door and told me that they are moving and aren't taking the Rambler with them and asked if I was still interested. Grabbed the chain and the 4x and hooked her up. It was sat there ten years ago and they set the parking brake which seems to be rusted in place. They needed it moved right away since their real estate agent was coming to take pictures of the house, so just dragged home.
    It's a v8, auto, AC, pretty straight, missing a couple pieces of chrome. Need to lube things up a bit, free up the rear brakes and clean out a mouse nest, then I'll determine what all needs to be done..
  2. Chopperrides
    Chopperrides
    Nice! it's to bad they didn't part with it back then. You probably ended up getting a better deal now though.
  3. calvinh
    calvinh
    Nice score and cool car. What motor is in it?
  4. Undercover Customs
    Undercover Customs
    I think it's the 287 but the neighbor thinks it's the 327. Have to look up the numbers. The air cleaner is suppose to be in the trunk(won't open) and not sure it the decal on it would show cubic inch.
  5. lo-buk
    lo-buk
    from kcmo
    Engine size decals were usually on the valve covers, that is where mine was.
  6. BEAR
    BEAR
    Nice score
  7. Undercover Customs
    Undercover Customs
    From the carb down to the exhaust manifolds is covered in mouse nest made from all kinds of ****. I'll get rid of that tomorrow and see what else lurks under there.
  8. havi
    havi
    Great score! These can make great sleepers.
  9. DrJ
    DrJ
    At least it doesn't have two too many doors.!
    Free is good.
    I can see that car looking pretty damn good with some '60's style grill, a floating or tunneled headlight area and tail light or rear trim mods.
    If it's got a rotted out timing chain housing (I think they had the bolt on housing that year maybe I'm wrong, again?) swap in a different engine.
  10. It needs a back half graft with ladder bars or four link. A narrowed diff with the biggest tires you can get under there. Some wheel tubs. A roll cage with extensions out to the front frame rails. Front springs need safety cable on upper A-frames to stop to much travel (springs can come out otherwise) open up the inner fenders and install the biggest meanest motor you can afford. Paint it "resale red" and have at it. (Actually a 401 or 425 nailhead would be wonderful in here. ) They are actually a very good looking car. They just need to be "ungrannied"
    Don
  11. busch
    busch
    Ungrannied is right
    nice score make a great little hot rod
  12. Bigcheese327
    Bigcheese327
    No, don't ungranny it! I like the sleeper idea. Pretend like it's 1966 and you want to go mess with GTOs and Chevelles.
    How about a 425hp/396 looking like it just got yanked from a wrecked '65 'Vette, widened steelies, and a four-speed? Just attach the stock wheelcovers with sheetmetal screws, and maybe mini-tub if necessary to hide your cheater slicks.
    -Dave
  13. fitzee
    fitzee
    I started with AMC and have a soft spot for them.This is a cool find. I try and see if I could get it running and on the road as it is with some brake work and a front end checkup. Cut the coils and add a set of chrome wheels and drive it.Don`t know if she has the tork tube or not but if it is it is a big job doing a engine swap.the rear end would have to swapped out and reworked to take ladder bars or leaf springs.
  14. oldwood
    oldwood
    from arkansas
    Survivor car!!! People at car shows like to see original.
  15. patrick66
    patrick66
    Mopar 360 with a Six-Pac set-up on it! Narrowed Ford 9" or Mopar 8-3/4" rear axle, 4.10:1 gears...now we're talking!
    Big drawback on the Ramblers is that they had the torque-tube driveline. Like Fitsee said, it can be overcome, though, if you wanted a modified drivetrain.
    Or, if you want to stay AMC, a 401 AMC engine would be ***s in this little Rambler. Stock interior with gauges under the dash. Some US Mags or Torque-Thrusts with blackwall tires. This has some potential! Far too many people dismiss these cars, just because. They make a great platform for all kinds of mayhem! Hell, look at the S/C Rambler Scrambler as a perfect example of what TO do to these babies!
  16. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    Cool - Good luck with the rehab. It's too bad that people don't take minumal measures to cover these treasures ! !
  17. Undercover Customs
    Undercover Customs
    I was told the motor was rebuilt about 15 years ago and has basically sat since. If it runs good and there are no ****** issues, I'll clean it up and use it as my driver for now. The interior is in great shape as far as no rips, tears or worn out springs and such- it just needs a good cleaning and new carpet. I would like to see it with 15 x 4 slots in the front and 15 x 8's in the back and about 2 -3 inches lower than it is now.
    If the motor and/or trans are shot, all bets are off. I like the Buick idea, a nailhead and a 4 speed. Time will tell.
  18. Dino
    Dino
    That was our family car when I was a kid. I always liked that car.
  19. RodStRace
    RodStRace
  20. greasemonkey060
    greasemonkey060
    Wait wait, so did you get it for free??
  21. Undercover Customs
    Undercover Customs
    No, but close enough.
  22. greasemonkey060
    greasemonkey060
    Damn. Still cool anyhow, especially if you've been bugging them to sell it to your for awhile!
  23. captainjunk#2
    captainjunk#2
    pretty cool score , post some pics of it being worked on
  24. 454navyss
    454navyss
    nice score. im surprised the tires are still holding air. i like the idea of keeping the sleeper look, big block, steel wheels with hubcaps and cheater slicks FTW
  25. Left Turn
    Left Turn
    from Omaha, NE
    Lower it, play with the grille (maybe a tube grille), shave the handles, swap out the tail lights (not sure for what but swap them for the sake of swaping).. I'd paint it a deep candy maroon or burgandy w/ lots of flake.. And a silver or gold flaked top (or maybe white pearl) maybe with some panels (or lace).. Interior would get a flake wheel (or have the stocker pearled), flake the dash and all the exposed sheet metal inside, and I'd go with either white pearl vinyl, or silver or gold flake vinyl to match the top.. Add a set of astros, star wires, or tru spokes on pinner whites and you'd have a sweet cruiser... I'd add a juice set up too and possibly a nice stereo system for some cruising tunes..
    Or you could go all aluminium 401 AMC, tub it, cage it, paint it black, and add a set of really wide and not so wide Torq Thrusts and go racin'!!
  26. This is a 67 but it was a compe***ive car. It was originally a Shell 4000 car. Vern Christy bought it from AMC and we pooled our meager funds so we both could go racing. That is Vern driving at Cayuga probably about 1969.
    401 is aslo a great motor. (this car was a 290). I have done a few Rambler Hi perf motors . The one that impressed me the most was the 360. it seemed to respond to everything you did to it.
    Having said that I am still leaning to a nailhead buick for that vintage Rambler. Narrow, big power and cubes, fits almost anywhere. I can just imagine it showing up anywhere with one at a cruise night. You would have to wait your turn to have a peak under the hood.
    Don
      23.9 KB
