Stock gages
Discussion in 'The Hokey Ass Message Board' started by jimbo50f-1, Mar 21, 2010.
  1. jimbo50f-1
    jimbo50f-1
    Hi, rewired my truck last winter ,went with American Autowire. Changed to 12 volt. Used GM 1 wire alternator. Wanted to keep stock gages so i put Runtz voltage reducers on fuel,oil pressure, and temp gages. They worked fine for a while and quit. So i put on new reducers and worked again fine for a little while and quit again. So my question is , is there another way to wire them so i can still use the stock gages? I've got after market gages under the dash for now but i want to loose them. Any suggestiions would be great. Thanks , Jim
  2. jimbo50f-1
    jimbo50f-1
    I forgot to mention the fuel gage is still working. I was wondering if I could use a bigger ceramic voltage reduser and run three feads from that to the gages?
  3. duste01
    duste01
    the voltage needs to be regulated, not just reduced.
  4. 29nash
    29nash
    from colorado
    It sounds like you are getting a voltage spike that's killing the Runtz. I would try powering them with very fine wire, 20 or 22 gauge a couple of ft in length coiled up somewhere out of sight. If it is a spike killing them, fine wire might do the trick. I had the same problem with my 6v electric wiper motor, with ceramic reducer. The motor kept speeding up, faster and faster. Small gauge wire did the trick.
  5. 333 Half Evil
    333 Half Evil
