Projects 1933 chevy 5 window coupe.
Discussion in 'The Hokey Ass Message Board' started by No car!!!!!!, Mar 11, 2010.
  1. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    I have had people tell me that someone welded two diffrent cars together.
  2. roddinron
    roddinron
    DON"T use a sand blaster on the sheet metal, it will warp the panels. If you're set on blasting it, use soda.
  3. vtwinpartss
    vtwinpartss
    from NOR CAL
    I used the hood from a 66 Chevelle
  4. flyin flattie
    flyin flattie
    from Redmond OR
    i always found my dads 33 to be the coolest ever he took the stock body ( that the previouse oner lost the top to) and made a new top out of a 4 door sedan and chopped it in the process. He also channeled it i think 2 inches if that just to make the side covers about a quarter inch from the frame. I think its sick but to each its own.
    Jet96 likes this.
  5. rsg2506
    rsg2506
    Here's a shot after we filled the roof on my 34. It's the only photo I could find.
  6. Jims35
    Jims35
    57 ford p***enger top metal.
  7. screwball
    screwball
    That look more like my 34 5 window the cowl to the fire wall on the 33 is shorter than the 34.
  8. chevyfordman
    chevyfordman
    Here is the smooth version
  9. Duke
    Duke
    On my A, I am planning on bolting my top insert in with hidden bolts. The insert will be metal (volvo roof) covered in fabric.
  10. ken1939
    ken1939
    Gee I wonder how many of those Buicks are even still around?
  11. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
  12. breeder
    breeder
    no car!!!!!! ????? **** to! you have a damn cool car!!!!lol lookin good man! should be a killer when your done!
  13. LOWCAB
    LOWCAB
    from Houston
    I'm with screwball on this one. It is not a 33. At least at the front cowl. The 33 had a shorter hood shelf so that would make it at least a 34. I had a 34 Master and a 35 Std.
    I filled the top on my 34 with the top of a Junk 65 Mustang. It had the right crown front to back and side to side.
    B
  14. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    Thanks breader the ression for the name. I maid this account before I owned a car and I was looking for one on hear but now I have one.
    And LOWCAB I welded that cowl on my self.
  15. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    It was a 1933 chevy master cowl if that changes anything.
  16. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    I have two 650 holleys would they be a good setup for a tunnel ram?
  17. heatnbeat
    heatnbeat
    from Madera,Ca.
    I got a chance to measure the 5 window it is 31" the 3 window is a few miles away I will check it out tomorrow
  18. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Thats alot.
    I think most tunnel rams use 500s or smaller
  19. 333 Half Evil
    333 Half Evil
    That depends on how you build the motor. I read one of your other posts about having a 396 BBC, so depending on how you build it(heads, cam, compresiion, etc) those would be fine....but if built wrong it won't matter.
  20. turney33
    turney33
    from pasco,wa
    I've got a 33 sedan redid insert,looks great! mine's white on black.
  21. modelamac
    modelamac
    my 33 has the fabric insert... I think that looks pretty cool? maybe even a little more traditional and not so street rod like the steel insert.
    also just to let you that a big block fits like it was made for it.... mine has a 454 with the 4 speed... and soon a factory tri-power from a 68 vette, if I ever get off my lazy A%# and put it on.
    anyway.... YEEEEHHHHAAAWWW it's a blast to drive.
    Good luck, looks like you have a good start.
  22. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    Thanks that would help me out a lot
    Scott.
  23. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    Thats a awsome looking rod nice job.
  24. LOWCAB
    LOWCAB
    from Houston
    This was that Mustang top fill I talked about above in my 34 master.
  25. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    Nice car and looks like a perfect fill to me. Not a fan of the green but still a nice car.
  26. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
  27. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
  28. No car!!!!!!
    No car!!!!!!
    from Sumner,wa
    All I have left now is to make my own floor pan.
  29. 8flat
    8flat
    Floor pans from a 33Ford will work, (nobody re-pops the 33 chevy floor). Not too expensive either, and you just have to do some t*******.
  30. 33_chevy
    33_chevy
    from TX
    I used a ford pinto
