Olds 350 valve adj?
Discussion in 'The Hokey Ass Message Board' started by lincolnolli, Mar 23, 2010.
  1. lincolnolli
    lincolnolli
    from Germany
    Hi folks!
    I put this Olds 350 out of a 77 Cadillac in a friends 56 a while ago.
    Granny car,engine condition was like new.
    Now he has some lifters tickin on the drivers side bank.
    Before we rip everything apart:
    Are the rockers adjustable,like on a SBC?
    Or do we need new lifters,cause theres no provision for that?
    thanks a ton,
    Ollie
  2. Did you check the oil level? Silly question but ticking was a sign on those motors that the oil was a bit low.
  3. 53sled
    53sled
    from KCMO
    Olds use a pedestal mount, so it is neither like a small block chevy, nor is it a rail mount without adjustment. I'd bet the motor has oil blockage from years of idling to church. flush it out and put in some 10-40.
  4. lincolnolli
    lincolnolli
    from Germany
    Yeah,thats all OK.Engine burns no oil at all too..
    thanks,
    Ollie
  5. lincolnolli
    lincolnolli
    from Germany
    Oh,OK!
    You mean like on a mopar,right?
    Makes sense,then i leave the rocker cover on and flush it and
    change oil+filter.
    Ollie
  6. ***Area-51***
    ***Area-51***
    from Ohio
    no adjustment, check out the lifters/valvetrain...tick is not uncommon on these when they get higher miles
    comp cam offer an inexpesive bolt-on adjustable roller tip conversion...
  7. DrJ
    DrJ
    The pushrods adjacent to the heat riser get plugged up with sludge from dirty oil getting cooked in them. Replace the center two Exhaust pushrods and rocker arms and it should fix it, unless the lifters are plugged too.
    Try just the two arm ***emblies and rods first.
  8. lincolnolli
    lincolnolli
    from Germany
    Wow,thats the insider knowledge is was hoping for,dr.j!!
    Great i'm gonna clean and replace that stuff first.Makes sense,i saw a lot of very bad oil cake on that spot over the years!On all kinds of V8s..
    thanks,
    Ollie
  9. BOBCRMAN
    BOBCRMAN
    from Holly
    For years all I did was remove the stand and shorten it (bench grinder) approx .020", stops the racket. Costs nothing and motor runs fine.:D
  10. holeshot
    holeshot
    from Waxahachie
    OLLI...who say's S.B. chevy's are not pedastil. hell pull 1 rocker cover, and see if their adjustibal. but brother there are all kind's of engine ticking. if your not SURE, well get a mechanic to listen...POP.
  11. plymouth1952
    plymouth1952
    main couse of olds rattleing.
  12. markjenks
    markjenks
    Yep, I agree, replace the center 4 pushrods.
    Trade it down by putting a screwdriver on the valvecover when it running and put your ear next to it. A old broom handle works good too.
    Trace it down to where the noise is coming from, most likely the center.
  13. auto shop
    auto shop
    from kentucky
    Look at the rocker arm pivots they where bad about wearing out. Replace the pivots and rocker arms curried the problem that I had. Make sure it's oiling.
  14. Super442s
    Super442s
    Rather than clogged pushrods, I would be more inclined to suspect the rocker pivots (or bridges) have excessive wear and therefore are creating a valvetrain clearance - rather than a preload on the hydraulic lifters. Due to the heat from the crossovers, the center pivots do tend to wear quicker than the outer ones. Since the factory pivots are made of aluminum, use care when unbolting and installing them if the cylinder you are working on has a valve open or you can break the pivot. If both valves are not in a closed position, remove (and tighten) the bolts back down equally.
  15. oldspert
    oldspert
    from Texas
    Also if you replace the pedestal ***emblies, be sure to torque them to the correct amount. They are only 5/16ths bolts and torque not over 35 Lbs. They will break easily and then you are in a world of ****.
  16. chubbie
    chubbie
    My 330 olds would always remind me it was time to change oil....tick-tick-tick
  17. 50dodge4x4
    50dodge4x4
    My aunt used to have an olds 350. Seemed I got to change those rocker pivots about once a year for several years. She thought she only had to change the oil at 3,000 miles, only problem, it often took a year to get to that 3,000 mile oil change and by then the rocker pivots were shot. I was real happy to see that one leave. Gene
  18. rtp
    rtp
    Yeah what Super 442 said. Also make sure the oil return holes at the corner of the heads are clear. If you have burnt oil gunk around valve springs it is going to end up clogging them up.
    rtp
  19. 56oldsDarrin
    56oldsDarrin
    "Seafoam" it, then drive it on the open road for 30 minutes. If its ticking after that, then open it up.
