Did the Machine shop hose me on my Nailhead?
Discussion in 'The Hokey Ass Message Board' started by ocool25, Mar 23, 2010.
  1. ocool25
    ocool25
    from Indiana
    Man what a deal! I have been waiting over two months to get my Nailhead back from the Machine shop and finally have it but the Crank doesn't appear measure out right. He told me the crank was good and only needed polished but when I measure the mains and the crank I have 0.003 to 0.004 clearance! Everything I find shows they should be 0.000 to 0.002. So the question is does it need ground and new bearings? it's a 1965 401
  2. RDR
    RDR
    Is you total difference .004 ? split that and it gives you .002 clearance all around...what does the plastigage say? ....my 2 cents worth
  3. Deuces
    Deuces
    Check your micrometer with a standard and make sure it reads zero. Then re-check the journal diameters.
  4. ocool25
    ocool25
    from Indiana
    I am using a bore gauge for the mains and a micrometer for the crank, guess I could get some plastigage but using the tools should be closer?
  5. ocool25
    ocool25
    from Indiana
    The micrometer is right on!
  6. Hotrodbuilderny
    Hotrodbuilderny
    If the crank polished up nice, and you are happy with it, just measure the journal and the bore with the bearing in and get a .001 or .002 under bearing depending on what you need
  7. E.C.
    E.C.
    from Tx
    Some bore gauges have too much spring pressure and dig into the bearing which will show more bearing clearance. You should also check rod bearing clearance.
  8. ocool25
    ocool25
    from Indiana
    Have been looking for 0.002 bearings but no luck any idea who handles them for the Nailhead
  9. ocool25
    ocool25
    from Indiana
    The rod clearance is the same story! I may bring home some Plastigauge tomorrow and check it that way, you are right the bore gauge does dig in some.
  10. 29nash
    29nash
    from colorado
    Yep. ***uming your'e measuring it right .004 is too much clearance. I have never had plastigauge let me down.
  11. Hotrodbuilderny
    Hotrodbuilderny
    Try Kanter, or maybe Egge, I like to measure them myself, but I always finish with Plasti gauge as said before I have never had it fail me
  12. Chief_Wannabe
    Chief_Wannabe
    from Ozark, MO
    I have a full set of measurement tools plus my own standards and I still use Plastigage as a sanity check. Plastigage has a bad rep and a lot of guys think it's a joke. I find it to be reasonably accurate for what it is, and very useful.
    It's so much easier to correct errors at the initial ***embly stage rather than later, and it's cheaper too. When I find measurement concerns, I always try to ***ume that I'm making the mistake, and try to prove myself wrong before I take it back to the machine shop.
    If you're confident in your measurements, take everything back to the machine shop and have them double-check it in front of you. I've had to do that many times. A good shop will stand behind their work and correct it, and turn it around in a timely manner.
  13. rjaustin421
    rjaustin421
    If you have a bore gauge then you should be able to nail the clearance IF you have a .0001 reading head which breaks each thousandth into tenths.
    You can use a .001 gauge head but it is pretty hard to interpret as the dimension from one side of a gauge line to the other is around 3/10's of an inch.
    With a bore gauge and a micrometer it really does not matter if the mic is correct as you are using these two tools as a comparator. Have the rod bearings installed in the caps and the caps torqued to specs (with lube!!!). Mike the rod journals, they really should be within a VERY few tenths of each other, and then lock the mic. Set the bore gauge with this mic and bring the needle to zero. Put the bore gauge in the rod in line with the beam and your clearance will be shown on the gauge. As you move toward the rod cap (parting line) the clearance will open up to accommodate the bearing "crush" which holds the bearings in place.
    If the crank is toward the factory low specification and the rod housing bore is toward the high the clearance will be big.
    This same procedure is applicable to the mains.
    If you have any questions as far as housing bore dimensions, crank dimensions, torque specs etc. feel free to contact me, I am glad to help!!!
  14. 29nash
    29nash
    from colorado
    Yep, that needs to be repeated.
    Sadly, that bad rep is perpetuated by people that don't know as much about what they're doing as they should. If one knows how to use it and read it, it's very accurate. I can't recall an instance where it disagreed with mechanical method to anything over .0005
  15. worken2much
    worken2much
    Get some green plastiguage. A tolerance of .000 is too tight. .0015 to .0025 is better. I'm ***umimg some hot rodding with these numbers.
    A half thousandth's is a very tiny amount indeed. If your measuring tool is digging into the bearing shell enough that you can see or feel it your measurement probably isn't accurate. The tools SHOULD give more accurate numbers than plastigage but I believe they are intended for use on hard steel surfaces.
    An extra half or whole thousandths clearance is far better than a thousandths too little. I once owned an ancient Minneapolis Moline tractor that had around 6 thousandths clearance on a rod bearing. If I kept a load on it and didn't rev it up too much it really didn't sound too bad. However, at a fast idle while stopped in the road for instance it would knock so bad it would make you wince! Used it that way for 2 - 3 years. Still running when I traded it off.
    Good luck
    Worken2much
  16. titus
    titus
    measure it with the plastigauge, just because thats what the mic says doesnt make it correct.
    jeff
  17. I prefer the Sealed Power foil strip gauges over plastigage.
    Haven't seen them for sale anyplace in years. What I have is 35 years old and still works fine. No guessing with this stuff.
  18. WhitePunkOnNitro
    WhitePunkOnNitro
    from Middle Tn
    The hotter the engine, the looser things should be down there. (to a point, of course) When I have cranks cut for street/strip engines, I always have the machinist take an extra thousandth. At higher RPM, this keeps the journal temp down and compensates for the extra twist and flex that happens when you spin things faster than the factory intended.
  19. coletrickle
    coletrickle
    If you can't find the bearings you need and need to tighten things up a bit you could try talking to guys that do the wetable coatings on piston skirts offically it will add 1/2 thou to a surface total of 1thou on a piston.I did a set of ducati pistons a couple of years ago guy said it had a bit of a rattle due to worn pistons loaded up the skirts with heaps of coating so nearly 2 thou bigger after coating.He hasn't been back.
  20. thunderbirdesq
    thunderbirdesq
    Also helps to handle the expansion from extra heat generated under pressure. Double check the measurements to be sure, if it's a thousandth bigger or so, I wouldn't worry about it. Better to be a hair loose than too tight!
  21. zman
    zman
    from Garner, NC
    Double check with the plastigauge.
    I'm not a fan of Kanter's plain white box bearings....
    LOL, the Nailhead isn't gonna spin more then 6k tops. Power will most likely fall off about 5300.
  22. bobss396
    bobss396
    I'd have no worries with .003-.004 total clearance myself. Better to err on being a CH loose than too tight.
    Bob
  23. WhitePunkOnNitro
    WhitePunkOnNitro
    from Middle Tn
    The standard unit of measurement known as the "CH" is .0035 inch. This can vary + or - by .0002, but the average is .0035
  24. Truckedup
    Truckedup
    So is this the correct way to figure bearing clearance? 1/2 of the total clearance? OH man,I.ve had some good running engines with really ****ed up clearances if that's true :D
  25. 42hotrod
    42hotrod
    from S.E. Idaho
    All of this about fancy expensive bearings and such for .001 or .002?
    Am I missing something? if its under have them turn the crank. if it polished at standard then it will easily clean up at .010 under. problem solved and common name brand bearing are available.
    Scot
  26. BinderRod
    BinderRod
    That would also depend on the color of the CH
  27. WhitePunkOnNitro
    WhitePunkOnNitro
    from Middle Tn
    My studies focused on the mid to lighter shades.
  28. Red and black err on the thicker side. Easier to see in the teeth tho..........
  29. ocool25
    ocool25
    from Indiana
    Zman:
    Where can I get the .002 main and rod bearings?
  30. ocool25
    ocool25
    from Indiana
    Lets see $100 for the grind and $175 for a .010 main set and $65 for the rod set or just $175 and $65 for .002 bearings? Wasn't that good in math in school but looks like a $100 savings to me!!!
