1949 chevy 216 oil filter accessory/ oil pump questions
Discussion in 'The Hokey Ass Message Board' started by Kool49, Mar 25, 2010.
  1. Kool49
    Kool49
    What is this and how does it work ? It bolts to the exhaust manifold i think ? I have a chance to buy one , my engine doent have one and was wondering why ? I hear that it was a option ? Do i need this ,and will it work on my 216 engine? Does the 216 have a oil pump ? How does the top end get fed oil ? I was told that my engine is a slinger type (rods) and i have no pump ! I was hoping to get the facts on this . Thanks
  2. Looks like this?
  3. Kool49
    Kool49
    Yes just like that whats its purpose and how does it work ?
  4. RDR
    RDR
    It's a byp*** filter not a full flow...does help to catch particles in the oil but being a byp*** not all the oil coming from the oil pump (yes you have an oil pump) is forced to go through that filter as in a full flow system...the 216 has a full pressure to the main brgs but the rods have a trough that they splash through for their oil along with a stream that is shot at them from a piping system as they come around on the down stroke...Not a good engine to abuse or overwork...they will probably last quite a while if driven as granny would but if you have hop up plans you oughta upgrade to 235 or 261....doubt putting a byp*** filter on at this point would do much for your engine...just keep oil in it and change it regularly... my opinion
  5. Hellfish
    Hellfish
    You really should buy a shop manual. The reprints are about $20 brand new.
  6. Kool49
    Kool49
    I have the shop manual , just looking for input on here! Thanks
  7. Kool49
    Kool49
    Thanks Inspector , that does help me alot with my decision. There are some things that a person can explain better to you than a manual does . I have the manual but it doesnt give this type of imfo in it . I appreciate your input.
  8. 6inarow
    6inarow
    A better filter arrangement might be the innerliner or similar that bolts to the oil distribution block
  9. BabbitBeater
    BabbitBeater
    from Colorado
    Does anyone repop innerliner oil filters?
  10. RDR
    RDR
    By the way Kool49 that is one good looking Fleetline!!...49 Fleetline was my highschool car in 1960...ended up with a 303 Olds in it and had a fun sleeper... hope you enjoy yours as much as I did mine.! Randy
  11. fbama73
    fbama73
    Being that I'm a few hours away from owning a splash oil 216, let me ask a question that I believe is obvious: You DO use only non-detergent oil in these, correct?
  12. BabbitBeater
    BabbitBeater
    from Colorado
  13. 29nash
    29nash
    from colorado
    You can, but conventional 10w30 works great. Or 15w40, 20w50 during the long hot summer.......
