Is is possible to fit an AC unit in a Model A gas tank?
Discussion in 'The Hokey Ass Message Board' started by Spyder, Mar 26, 2010.
  1. Spyder
    Spyder
    from Houston
    Anyone ever put an AC unit inside the original dash gas tank in a '28-'29 Ford? It seems like maybe it's too small. Say what you must about Hot Rods not having AC, Houston gets HOT.
  2. Zartman456
    Zartman456
    You might be able to use one of the aux. type ac units found in the back of conversion vans and limos. I know that could be made to fit.
  3. troylee
    troylee
    I have put 1000 mini's from Vintage Air in Model A's. Not much room, gut the tank and it fit in there. I put the gen ll in 33-34 the mite fit in a model a. You will see most of the box.
  4. pitman
    pitman
    Mostly it sounds like fitting an evaporator and getting air flow in, and out to p***enger area are the "dimensional" issues
  5. Slick Willy
    Slick Willy
    anythings possible...:D
  6. art.flame
    art.flame
    i've done it
  7. 8flat
    8flat
    That is wild.....good job.
  8. Spyder
    Spyder
    from Houston
    Art.flame, was the a kit, or something you pieced together?
  9. 41 C28
    41 C28
  10. art.flame
    art.flame
    ac came from vintage air ,have look what type it was ,but one of the smallest they offered
    the only thing i made where a few brackets but only because i didn't like the ones they had
    Art
  11. art.flame
    art.flame
    here's a pic from the inside
  12. art.flame
    art.flame
    another one
  13. The lowbuck guy could look at rear A/C units from minvans or like a Chevy Suburban, I know the Suburban one isn't that big under the plastic housing, and uses a lot of standard GM connections and so forth.
  14. Spyder
    Spyder
    from Houston
    Thanks folks. I'll really be thanking you in August.
  15. SakowskiMotors
    SakowskiMotors
  16. Spyder
    Spyder
    from Houston
    An early compressor would look better, heavy though.
  17. SakowskiMotors
    SakowskiMotors
