somebody was trying to tell me my engine is a babbit pounder.
Discussion in 'The Hokey Ass Message Board' started by yorgatron, Mar 29, 2010.
  1. yorgatron
    yorgatron
    are you ****ing kidding me? :confused:
  2. 52HardTop
    52HardTop
    I would say they were!
  3. ironfly28
    ironfly28
    from Orange, CA
    so what?.......... drive it.
  4. hotroddon
    hotroddon
    Uh, the point of this thread is ??
  5. yorgatron
    yorgatron
    just proving a point.
    thank you for stopping by though,be sure to come again! :rolleyes:
  6. hotroddon
    hotroddon
    I guess I'm missing something. What point did you prove? :confused:
  7. Ice man
    Ice man
    If its a low oil pressure engine, its a babbit pounder, if its a hi oil pressure engine its inserted. Iceman
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Well, I can tell from the picture that it isn't. Do I win the intake?
  9. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    depends on the year. They switched to full pressure in 1954, but not on all models. In 55, all were full pressure insert style bearings, but the cams were different depending on transmissons. One got a solid lifter cam, and the other hydro.
  10. ironfly28
    ironfly28
    from Orange, CA
    what year is it?...and what's wrong with babbit? I guess if you're running nitro methane and you have to tear it down after every p*** it could get mildly annoying.. but some people still pour babbit, and ALOT of guys here run babbit motors with no real trouble other than the fact that.......well, they're old motors. all of these motors need more attention than a new honda but let's see how those engines do in 50+ years.
  11. Paul
    Paul
    Editor
    bolts at perimeter of valve cover tells me it's not
  12. Truckedup
    Truckedup
    Side motor mounts says it's a 58 or newer engine.Low water pump says it's a 55 or newer engine.In 1954 all Chevy 6's had the hi oil pressure engine with the PG engines being the same in 53.
    Babbit? you bet,most all engines have babbit cam bearings.:D
  13. Little Wing
    Little Wing
    from Northeast
    neat lil looking motor regardless
  14. Mr48chev
    Sounds like something that you should have posted in the "what the self styled experts said about my ride" thread. It's pretty obvious to most of us that it is a 58 or later engine that has insert bearings.
    But then maybe you dressed it out in a way that messed with their minds a bit before they opened yap and inserted foot. Award= one point for fooling the know it all.
    Now if someone says the same thing about the 292 that is going in my 48 when I get it squared away I'll stand there and grin like a chessie cat and let it go.
  15. jcmarz
    jcmarz
    from Chino, Ca
    The style valve cover is one sign that the motor is not a babbit. There is a 2nd sign that says its a post 54 and not a babbit. Don't believe everything people tell you. Always do research. Buy books, old repair manuals like "MOTOR" ETC.....ETC.....so you know exactly what you have:D
  16. 6inarow
    6inarow
    I can tell you one thing - you will never sell it with the description you have.
  17. zman
    zman
    from Garner, NC
    ahhh... the newbs, gotta love em...
  18. Cosmo49
    Cosmo49
    http://www.inliners.org/, you tell us, casting #'s on left hand side, give it a click and tell us what year you have...
  19. Deuces
    Deuces
    ........ And here I'm thinkin' someone with a ****ie motor tore you a new one....
  20. Hnstray
    Hnstray
    from Quincy, IL
    Yes, it does depend on year, but you are off by a year. In '53 Manual shift equipped engines were low pressure, babbited bearing engines and Powerglide engines were full pressure lube insert bearing engines. They outwardly looked pretty much the same in that the valve covers were still the old style two bolts through the top. In '54 ALL engines were full pressure/insert engines and the valve covers went to perimeter screws.
    Ray
  21. Rickybop
    Rickybop
    You said "****ing". I'm tellin'.
  22. gimpyshotrods
    gimpyshotrods
    Insert bearings are lead babbit bearings too, just not poured into the block.
  23. 61 chevy
    61 chevy
    did ELMER FUDD kill a babbit ?
  24. Fordguy321
    Fordguy321
    from Arizona
    all i know is thats a cool intake!
  25. Grumpy
    Grumpy
    from NE Ohio
    Thats what I was thinking...
    I know the 53-54 cut off for full pressure etc, but I believe those to be center bolt covers...
    I believe the early 54 non-high pressure were center bolt. Making them babbit...
    But Im no expert...:D
  26. Who gives a damn? I guess I'm the dumb **** for clicking on this stupid thread.
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    DON'T!!!!! We'll all be grounded, and I'll miss Spring Carlisle!!!!!
  28. OLLIN
    OLLIN
    Yup.
  29. junkjunky
    junkjunky
    the splash lub"235" engines have a triangle shaped sheet metal cover ahead of the motormount on the side shone in picture.it covers an oil line in the cranck case.
  30. phlip
    phlip
    You should've punched him right in the face.
