1947 ford window help
Discussion in 'The Hokey Ass Message Board' started by tudorkeith, Mar 29, 2010.
  1. tudorkeith
    tudorkeith
    The body work on my 47 is coming a long so well that I want to remove the rear window and windshield in order to do a complete job. We're replacing the sides and front but I am going to need to reuse the rear. I've removed windshields before, is the rear window done in the same piano wire method? Or am I better off just leaving the rear in and sanding up ti the surround? there is no rot around the windows, just old paint. thanks for any help I get
  2. papastoyss
    papastoyss
    I use a sharp knife & cut the gasket to be sure I don't break the glass. New rubber is cheap compared to finding a good rear glass.
  3. phat rat
    phat rat
    I agree with papastoyss. But if you do break it or someone wants new glass this place has new. They have even have it tinted.
    http://www.theglasshouse1.com/products.htm
  4. Nelly
    Nelly
    Not sure if you are already aware of this, but the rear window goes in/out from inside the car.
  5. lakes modified
    lakes modified
    The windshield does also.
  6. tudorkeith
    tudorkeith
    thanks guys, rear window was a breeze, windshield is a little bit of a pain. but I can handle it
