Powered By Ford Thread
Discussion in 'The Hokey Ass Message Board' started by FordMaverickFanatic, Mar 5, 2010.
  1. Berdoo John
    Berdoo John
    400 (Lincoln) in the F100 - (excuse the sbc powered Willys ;))
  2. mustangdug
    mustangdug
    My 29 coupe that i been on and off doin for the last five years, getting ready to fire it up this week! The frame is 6" over and has a 4" recessed firewall and the blower pulley is 3/4" away from the rad! Trans is a 69 big input Toploader with a Jeep t176 top shifter and rear is a 8.8 out of and explorer, 4:10's 31 spline and a trac-loc. Should spin them hurst's pretty well!
  3. hey black coupe. that 32 is WICKED very nice me lickey alot
  4. TF50
    TF50
    from Minnesota
    Not very traditional like you all like, but
    5.0 EFI in my F-1
  5. Sanford&Son
    Sanford&Son
    from Visalia,Ca
    :cool: 302 / C-4 / 9"
  6. SIX GUN
    SIX GUN
  7. mattfink
    mattfink
    ^^^^^Awesome setup, excuse my dumbness what motor is it?
  8. how are these my roadster pu
    347/aod/8" with a spool
    and the henry J
    4.6 fuel injected 26 mpg
    eaod and amc 20 rear
  9. Paulie9fingers
    Paulie9fingers
    The Blue Thunder has a larger universal casting where it meets the head and they just open up the port for the SCJ heads. Mine was cast the same as a standard port factory intake, when the intake was on the engine there was actually a 1/8 inch gap between the top of the intake port flange and the roof of the intake runner, you could still see right into the port :D.
  10. Black coupe
    Black coupe
    Thanks 57ford/60thunderbird
  11. SIX GUN
    SIX GUN
    It's a destroked 300 (272ci) Ford truck engine, makes around 420HP, has gone the best of 10.96 @ 120mph in the 1/4....
  12. FordMaverickFanatic
    FordMaverickFanatic
    from Taylor, MI
  13. buzz4041
    buzz4041
    from Texas
    Droppin a SVO 351W in my 40 Ford pickup ch***is. Should be plenty for that little pickup
  14. This is in my 32.
  15. ronk16
    ronk16
    351 m beastie.....[​IMG][​IMG]
  16. bulletproof1
    bulletproof1
    from tulsa okla
    having my first ford powered ford I'm not to impressed with the ford brotherhood.its like pulling teeth trying to get info or advise on building a ford motor..
  17. 29 bones
    29 bones
    from so cal
  18. Rice n Beans Garage
    Rice n Beans Garage
    Here's my SLOW-89, Comp cam, Cobra dual plane intake, Edelbrock carb, hooked up to a Top Loader..
  19. SuddenDeath
    SuddenDeath
    from Florida
    Working on restoring it back to its original configuration as it was in 1976/77. Built by Gapp & Roush. Took these pics just this week after finishing installing new master cylinder, new 5 lug rotors, calipers, hoses, etc. Along, with finally getting the restored wheels and new tires on!
  20. AnimalAin
    AnimalAin
    Is that "Sudden Death" that Baskerville wrote about in Hot Rod?
  21. SuddenDeath
    SuddenDeath
    from Florida
    The exact car...found it a few months ago and am restoring it back to its appearance in the "Sudden Death" article Baskerville wrote for the April '77 Issue of Hot Rod mag.
  22. johnnie
    johnnie
    from indiana
    Benn following your progress on another forum too. That car is awesome! I am so glad you are keeping it "as built". I only read one article and finally saw the others in your posts. That car made a long lasting impression on me! So cool, dude! Thanks.
  23. johnnie
    johnnie
    from indiana
    Shouldn't have that problem with guys on here! If that is so, there are forums for each Ford engine family. Windsors, 335s, FEs, 385s, MEL, Y-block, flatheads are all covered with great advice from experienced people.
    Hell, even I know a little about the '60s-'80s stuff!
  24. SuddenDeath
    SuddenDeath
    from Florida
    Good to meet you! Thanks for the comments. My plan is to put the car back as exact as I can to how it was done in 1976/77 in the article everyone remembers it from. I have made a couple of minor changes so far in the name of safety, using the stainless fuel lines/AN fittings under the car. Originally, they used all rubber hose and worm clamps from tank to carb.
    I also swapped the front wheels to 5 lug, only because I can't get the right tires to fit the 13" wheels any more. I contact both Kelsey Tire and Coker Tire. Both told me they have no molds any more and don't plan on making them. I told them both, "too bad, since there are dozens of models of cars being restored today from the early 60's thru the 70's that use them".
    BTW...I like that 57 Ford you're running! What are you running for power?
  25. johnnie
    johnnie
    from indiana
    Sadly, the car in my avatar isn't mine! A forum member saw my signature and turned me on to that pic. I have a '66 Comet 2 dr sedan project.
    The changes you have made, I would have made too. Safety is a valid concern and I think the 5 bolt wheels, matching the rears, looks right anyway. Should have been that way when it was built. It looks good with either color, but I hope you put her back to the silver (or was it painted during the turbo version?). Be following ya!
    John.
  26. kustombypook
    kustombypook
    302 and C-4 going in my Edsel. Getting close. Going to polish and paint the valve covers.
  27. M.Edell
    M.Edell
  28. pauls fords
    pauls fords
    I'm in all the way, my avatar is a chopped 51 with a 91 lincoln 4.6 sohc, aod, 9 in posi, my other projects are a 51- F1 with a 95 lincoln 4.6 sohc, aod ---- a 54- F1 with a galaxie 406 3x2 4 speed motor --- and a 51 vert with a 49 lincoln 337, hydromatic 4 speed, ALL FORD ALL FORD PARTS except the hydro.
  29. toxictom
    toxictom
    warmed 302 in my 29 roadster
  30. goford51
    goford51
    from griffin ga
    302 c-6 9in rear in my 51 18mpg
