converting mechanical drum brakes to hydraulic
Discussion in 'The Hokey Ass Message Board' started by marlon, Apr 1, 2010.
  1. marlon
    marlon
    Hi, i don't know much about mechanical drum brakes but i know that i would need to convert them to hydraulic. I have my eye on a nice axle at my local yard but it has mechanical breaks. I was wondering if it is possible to convert them and if so how.
    thanks Marlon
  2. First off, they're brakes, not "breaks". Secondly, the make model and year of car that you're working on and the same info for the axle might help just a tad
  3. marlon
    marlon
    the axle is a ford but i do not know the year, its early 30's/ late 20's
  4. Flatheadguy
    Flatheadguy
    Front or rear axle? It sorta matters. Both are easily converted with the right parts.
  5. Okie Pete
    Okie Pete
    Have you tried the tech archives ? Photo's of the axle would help. Good luck on your build sounds like fun.
  6. Hitchhiker
    Hitchhiker
    If you search the tech archive all will become clear. It will tell you how to identify the axles and how to covert them to disk brakes along with many other useful tidbits.
  7. marlon
    marlon
    front, i can put up photos tomorrow
  8. wbrw32
    wbrw32
    This is gonna be good.............
  9. Dyce
    Dyce
    This is a set I found someone converted.
    I might run them just for ****s and giggles. I would recomend finding some f-100 front brakes if you go with drums. They are self energizing and balance out better if you run a late rear axle.
  10. marlon
    marlon
    sorry for the delay, i am going to pick up the axle from the yard right now, than i will upload some photos
