Tech Week Threads 4/2-4/16
Discussion in 'The Hokey Ass Message Board' started by zman, Apr 2, 2010.
  1. zman
    zman
    from Garner, NC
  2. Double Caddy
    Double Caddy
    from virginia
  3. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
  4. zman
    zman
    from Garner, NC
    I figure you've been around here long enough to see a few tech weeks. But this is not really the way it works. Submit a tech thread during the allotted time, in this case from now until the 16th.
  5. woodbox
    woodbox
    Is it Tech 1/2 Month or TECH FORTNIGHT? What ever it is Im subscribing!
  6. thunderbirdesq
    thunderbirdesq
  7. zman
    zman
    from Garner, NC
    and here we go....
  8. dabirdguy
    dabirdguy
  9. zman
    zman
    from Garner, NC
  10. finkd
    finkd
    *** Tech**** it has always been a problem to figure out how to do the gl*** when chopping a top, so I'm going to show how I do it. First I wax the windshield that came out of the car, any ol wax will do. Then I use fibergl*** and @ layers of matt, just put it right on top of the waxed gl***, work out all the air bubbles and try to get it *** smooth as you can. overlap the gl*** by a couple inches. let it cure ( sometimes overnight). then take a sander , or air hacksaw and trim it too the size of the gl***,sand edges smooth. then put the gasket on the chopped car, and trimm the fibergl*** template to size, I like it a lil on the loose side, gl*** won't break if it has some room to move around. then trace the new size onto the gl*** to be cut and , there you have a nice template, for cutting your new gl***. I know this isn't a metal working tech, but the answer to a question asked many times.
  11. littlechris
    littlechris
    from MILWAUKEE
  12. Flat Ernie
    Flat Ernie
    Tech Editor
    Great Stuff - start a new, separate thread with this info in it. Then come back here and give us a link...
  13. rottenleonard
    rottenleonard
  14. Flat Ernie
    Flat Ernie
    Tech Editor
  15. bbanks12
    bbanks12
  16. finkd
    finkd
  17. Okie Pete
    Okie Pete
    Well here's mine. It is bike related . If i build another one i will use rectangular tubing . I used channel iron and had to take it apart to box it . The table is made out of flooring for a hog feeding floor. The wheel clamp was purchased. I use a 1/2 drive ratchet to raise or lower it.
  18. George G
    George G
  19. the-rodster
    the-rodster
  20. tony31a
    tony31a
  21. Duke
    Duke
  22. Last edited: Apr 8, 2010
  23. zman
    zman
    from Garner, NC
    Can you put them into their own thread?
  24. Streetwerkz
    Streetwerkz
  25. zman
    zman
    from Garner, NC
  26. Streetwerkz
    Streetwerkz
    thanks.... I'm not so smart ya know lol
  27. zman
    zman
    from Garner, NC
    LOL, no sweat... thanks for taking the time to put it together...
  28. tdog
    tdog
    from Omaha, NE
    Not sure how to enter this in tech week? I posted this in the other "sticky" thread. anyway here it is.
    http://www.jalopyjournal.com/forum/s...ighlight=banjo
    Showing all the steps of a banjo rear end build. Plus using a rope to lock up the diff with one axle to set the preload on the differental bearings with an in/lb torque wrench. Not by "feel"
    <!-- / message -->
  29. metalman
    metalman
  30. zman
    zman
    from Garner, NC
    It was already on the list...
