Are the doors on the three-window coupe the same length as the doors on the roadster? Thanks for any help! Actual dimensions would be especially appreciated!
NO.....just went out and measured the doors on my Roadster and Three Window, both Ford original steel cars. ROADSTER: Top of door, right above the top hinge in the crease of the belt-line 34 1/2" gap to gap. Bottom of door, 36" gap to gap. 3W COUPE: Top of door, below hinge, in crease of belt-line, 40 3/4" gap to gap. Bottom of door, 42 1/8", gap to gap. Hope this helps, let me know if you need any more measurements. Johnnie.
Thanks, Johnnie, this is exactly what I needed, and really appreciate your taking the time to measure your cars. I'm beginning work on a model of the Bob Hooper roadster using AMT's circa-'61 kit, which offered the option to build a roadster or 3W using the same body, and the doors seemed too long comparing to photos of the Hooper car in TRJ! In fact they are.
