pullmax p9 max load amps
Discussion in 'The Hokey Ass Message Board' started by nightperson, Apr 6, 2010.
  1. nightperson
    nightperson
    anyone know what it is? my tag is not readable and i need to know this so i can get the right phase convertor- it has 20 amp fuses in the box so i know its below that
  2. redo32
    redo32
    Has your motor been changed? Might need more info. My P9 has the Swedish 2 sp 440 volt motor. High speed is 6 hp and 8.7 amps. A 6 hp 220 motor will pull twice the amps. I'm running mine thru a step up transformer. It's on a 220 volt 20 amp breaker.
  3. HemiRambler
    HemiRambler
    IIRC mine runs on a 10hp converter (rotary). Factory 2 speed motor. Low speed wasn't a problem with a lesser converter but startign directly on HIGH SPEED was an issue.
  4. SakowskiMotors
    SakowskiMotors
    If you call me at the shop, I will look at my P9. Is it the original motor?
    How about pictures of what you have, to help compare?
    What year is yours?
    Wil
    910 399 5939
    www.sakowskimotors.com
    www.ridefree.com
  5. jalopys
    jalopys
    from El Paso TX
    Changed my motor cuz the one i had was out.
  6. nightperson
    nightperson
    here is the motor- i was told from the guy i purchased it from its 3hp- seems large for 3 hp- i have a 5hp motor on the compressor and its not this large
    im not sure if its original or not- 1961 is the year pullmax told me when they ran the serial number
  7. Russco
    Russco
    from Central IL
    If you call Stan Fulton at Fulton metal works I think he will be able to help you out. He refurbishes and sells Pullmax machines and tooling (217) 476-8223
  8. nightperson
    nightperson
    thanks- didn't know stand refurbed machines, just thought he made dyes- he was a big help. after talking to him i think im going to just get a 230 v, 3 hp 1 speed>VFD with foot pedal and just be done with it
  9. 51Gringo
    51Gringo
    from Nor Cal
    With a frequency drive, you'll be able to change the speed.
  10. heatnbeat
    heatnbeat
    from Madera,Ca.
    Thats what I did works GREAT!:)
  11. nightperson
    nightperson
    what rpm motor should i get as the replacement?
  12. Irrational Metalworks
    Alliance Vendor
    from DFW
    Looks like the same motor on my P9. Mine is a 5 hp.
