12 bolt truck help... gov lock
Discussion in 'The Hokey Ass Message Board' started by lowdown and dirty, Apr 7, 2010.
  1. lowdown and dirty
    lowdown and dirty
    ok fellas,
    im thinkin of swapping my 3.73 gear for a 3.08.. also thinkin of throwing in a gov lock... yes ive read all the bad **** about them.. here's my combo.
    65 c-10
    mild 4bolt 350.. +/- 300 hp
    close ratio saginaw 4speed. not sure of the gears but has a real low 1st.
    12 bolt truck rear
    questions.
    -is the gov lock a bad idea?
    -how can i tell between a 3 series and 4 series gov lock?
    -does anyone know for sure the gear cut off between 3 and 4 series carriers... ive read that 3.73 can be either 3 or 4 series????
    thanks in advance
  2. lowdown and dirty
    lowdown and dirty
  3. enginebloch
    enginebloch
    from norfolk va
    Hold off on the gov loc, I have found the superior 12b truck clutch type posi units under some 4x4 trucks and blazers.
    When that gov loc engages it is very violent- imagine one side of the rotating ***embly of the axle moving 200rpm faster than the other (20lbs tire + 20lbs rim + 20 lbs of axle shaft and brake drum) vs the inertia of the same ***embly at a complete stop. The shock load will either granade the gov loc or snap the ****py c clip axle shaft. I have seen the aftermath and it usually includes a new ge****t and carrier as well as body work for when the axle falls out.
    I would just search for a complete axle or a mated gear and carrier as most of them were 2.73s or 3.08s already.
  4. xsquiden
    xsquiden
    We got a complete rear posi 3.73 truck 12 bolt that was in good shape from a salvage yard here for $250 all we had to do was call then drive to pick it up. That might be a solution.
    later
    mike
  5. lowdown and dirty
    lowdown and dirty
    i have two 12 bolts.. one with a 3 series one with a 4. im gonna rebuild one either way, because i want to be able to count on it 100%. ill probably look for a better posi. what i really need to know is the gear cut off between 3 and 4 series carriers???
  6. TagMan
    TagMan
    I have the "granny" 4-speed (1st gear is 6.08:1) in my '63 C10 with the 3.73 rear ratio. Instead of changing the rear end, I located a NPG A833 3-speed w/ OD transmission that was used on Chevy trucks (1972-1978, as I recall). First gear is around 3.09:1 and OD is around 0.7:1. I haven't had a chance to install the transmission due to recovering from a long term illness, but I hope to get it in this summer.
    There were two versions of that transmission used by Chevy: One had the MOPAR bolt pattern and the other had the SBC pattern. If you find the MOPAR one, make sure you get the bell housing with it.
