2 questions regarding flathead/T-5 & Model A axle ratios...
Discussion in 'The Hokey Ass Message Board' started by Rocky, Dec 28, 2004.
  1. tommy
    tommy
  2. Great post with some great results. Again, Graeme McNeil at www.macsspeed.com manufactures a bellhousing adaptor for T5 to flathead.
    Best regards,
    Greg Stokes
  3. av8
    av8
    Makes perfect sense. The trans is locked up in Tardel's shop until he reopens next week, but I should be able to tell what I have. Thanks.
    Mike
  4. cadzilla
    cadzilla
    any body need a t5 trans i have them all?? .or if not can get them let me know
    tim 757 254 2493
  5. Fenders
    Fenders
    The first two numbers are pinion and ring tooth count. Don't need a chart, just divide the first number into the second. Typically rounded off to hundredths.
  6. steelartist
    steelartist
    don't blow it on a T5. go with a tr3550 or tko500. uses the same toploader 4spd. bolt pattern from early 50's to mid sixties fords. use this link to gain more info on the subject. good luck.
    http://www.5speedtransmissions.com/tr-3550.html
  7. TurboRay
    TurboRay
    Hmmmmm...............speaking of "blowing it", the cheapest ****** I saw on that site was $1895. [​IMG]
    C'ya - RAY
  8. Rocky
    Rocky
    Classified Editor
    All good info but I've since sold the 50 engine to av8 and used my S-10 ****** in my 33 pickup.
    Now, I have a brand new problem with T-5s....got a 4 cylinder version [still a world cl*** from a '93] but it has a really weird bolt pattern. I dunno if it'll fit anything other than a 4 banger S-10 truck. The pattern is very narrow but really tall, top to bottom. I put it up against a chevy bellhousing and it appears one bolt hole matches up but the two bottom bolts holes are about 2 inches below the iron chevy pickup bellhousing.....nothing but air to bolt to. I was thinking of fab'ing up some heavy "L" brackets that bolt to the bellhousing inspection cover bolt holes and.....well, cobbling sounds like a pretty accurate description of my idea. Maybe a thick adapter plate is a better idea.....
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    Rocky,
    You can find T5 cases pretty cheap on eBay - easy to swap guts from one to another...
