28 Closed Cab Pickup Cowl and Floor Mounting Idea's
Discussion in 'The Hokey Ass Message Board' started by tmacracin, Oct 4, 2009.
  1. tmacracin
    tmacracin
    We were doing some mockup on my 28 Ford closed cab pickup and are looking for some ideas on cowl band mounting and floor construction.
    2"x4" frame,4" Z, with the cab channeled 4". I was thinking 1"x2" rec tube subrails with 1" square tube floor framing? My camera is being a pain in my *** tonight but I will try and post some pictures.
  2. tmacracin
    tmacracin
    Steel or aluminum for floor skin?
  3. srosa707
    srosa707
    from Sacramento
    I did 1x2 in my floors. Came out decent. Then I covered it in stained plywood. Turned out decent for a garage build! I always get compliments on how it turned out.
  4. tmacracin
    tmacracin
    I was thinking of using 1"x2" tubing for the whole floor also.
  5. tmacracin
    tmacracin
    What is the best way to mount a cowl band to the frame on a channeled Model A?????
  6. The Chop Parlor
    The Chop Parlor
    I've got a 34 Ford truck and I'm working on figuring out how to mount the cab the same way. Are you planning on welding the box tubing to the firewall, sides, and rear of the cab and bolting that to the frame or what?
