Model A crossmember
Discussion in 'The Hokey Ass Message Board' started by prewarcars4me, Apr 15, 2010.
  1. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I have a cnc plasma and just finished programming a fairly stock looking front Model A crossmember to cut out.
    Mild small block/auto, 2 door sedan.
    My question is, what thickness of steel is a stock front one? This isn't like Speedways that is almost straight, this has the save "v" as a stock one. What size do you guys think I should use?
    Thanks.
  2. N8B
    N8B
    Don't know stock I could run out and measure it for you in a bit but I would believe 3/16" would do ya good.
  3. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    If it is convienent, if not, don't sweat it. I am hoping to start in on the frame on Saturday if I can get the time.
  4. shinysideup
    shinysideup
    from ruskin, fl
    I measured just under 3/16.
  5. KUZTOM
    KUZTOM
    Just had a look at ours , just a tad under 4mm.
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Looks like 3/16" it is. Thanks guys. :)
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    5/32,,,,,, I had to go look at a conversion chart,lol.
  8. wheelbilly
    wheelbilly
    Really? I was thinking .090 would do the trick after looking at stock rear cross members and trying to remember what my front was. From a model T however. .1875 huh?
  9. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I would have thought 1/8", but seeing how they actually measured one, I have no issues doing 3/16"
  10. bct
    bct
    what size are your u-bolts? 2 1/8" might be harder to source
  11. cadillacoffin
    cadillacoffin
    7ga .175
    3/16 .188
    either should be fine
  12. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Bolt tabs on front and back, with a retainer plate bolted directly, no "u bolts".
