Battery Drain Issue
Discussion in 'The Hokey Ass Message Board' started by ScottyVenture, Apr 17, 2010.
  1. ScottyVenture
    ScottyVenture
    New guy here.
    I have a battery drain on my Ford. I disconnected the negative terminal and put a circuit light between it and the battery - light comes on.
    I unhooked all the extra connections and narrowed down the problem to the fact that my negative terminal grounds on the engine block, and there's a circuit running from there through my block to my alternator, and back to the positive terminal.
    So as far as I can figure, I have these options:
    -insulate the alternator.
    -relocate the battery ground.
    Is there any other options? what would the HAMB do?
  2. Bigchuck
    Bigchuck
    from Austin, TX
    Alternator has bad diodes.
  3. I agree.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    It is always good to have secondary grounds running from block/trans to frame, body to frame as well as the common battery to block hookup. As my Grandpa used to say "You can't ever have too much ground." He probably wasn't speaking electronically but it fits.
  5. T. Scott
    T. Scott
    hook up a multimeter to the disconnected term**** and the empty post and read the volts if its on like 5 to 12 you may have something on in the car (like on On) if a light bulb or something like that is on and gives a continuos drain it should show up and will read on a meter the way i before mentioned .. check it out hope this helped good luck
  6. T. Scott
    T. Scott
    what i mentioned befor BTW is in the case that if the problem just showed up and it was not doing this before .... just thought it would be worth checking
  7. ScottyVenture
    ScottyVenture
    Well I took the alternator down to the parts store and sure enough, it was bad.
    Just got the new one back on and retested....I still get a light. :confused:
  8. ScottyVenture
    ScottyVenture
    Problem is I disconnected all the stuff except what's between the battery, block and alternator.
  9. 325w
    325w
    Leave the light hooked up and pull a fuse at a time. Hopefully when you pull the right fuse the light will go out. Then you have to find the problem in that circuit.
  10. Cymro
    Cymro
    Silly Question, but do you have a clock, radio, tape / cd player hooked up that is a constant but small drain on your battery? then follow the advice given by 325w. |If you have a short somewhere the fuse should blow.
  11. Cymro
    Cymro
    OOPS a fault in the car alarm ***uming you have one fitted could also be a small drain on the battery. The favorite with my european Ford was the Trunk light Switching on and off of its own accord, dodgy switch but being intermittent it took ages to find.
  12. AnimalAin
    AnimalAin
    My roadster had a persistent and hard-to-find charging problem. Finally fixed it by making the battery ground better. It sounds like you probably have that well in hand, so the diodes in the alternator are probably a good place to start. Good luck on this; it is a frustrating problem.
  13. gimpyshotrods
    gimpyshotrods
    Chasing ghosts. Ain't it fun? Check everything, even the things that you would not expect.
    I just now, finally found the battery drain on a 1964 falcon that I have in the shop. It turned out to be a bad stop light switch. It was ever-so-slightly lighting up the brake lights, all of the time. The glow was barely visible in pitch darkness.
    I have always figure that switches either work, don't. Now I have found a third-state.
  14. ScottyVenture
    ScottyVenture
    Got the light to go out...by converting it back to a 1 wire system. Will a 3 wire drain unless you have both wires hooked up?
  15. AnimalAin
    AnimalAin
    Remember, despite what engineers tell you, it's all magic. If it works, don't **** with it.
  16. gimpyshotrods
    gimpyshotrods
    Not all 1-wire alternator regulators can go back to 3-wire.
