My buddy Eltoro has a chance to inherit his abuelo's pick up and he sent me the picture in hopes of figuring out the make and year. Perhaps its the head cold, but I cant seem to nail it down. Anyone else want to take a stab? Much appreciated....
I first saw the windshield shape and thought mopar...but the rear fenders don't look like mopar. Did you notice that the beltline details on the door do not follow onto the hood?
I do and I'm starting to think this might be a custom job, I mean look at the name of his business; he'd certainly be capable, but I cant match that cowel detail either....
Yeah, the top ends very abruptly. I was thinking built from a sedan too . I've not seen anything like it . Also the door is longer than truck doors from the time,like a 2dr sedan.
Hi, Looks like a composite/custom. The main body is a cut down 35 Plymouth p***enger car. Front fenders, running boards, hub caps and artillery wheels from the same 35, therefore would also expect the ch***is and running gear to be 35. Not 36 because of the rounded bottom corners of the windshield (36 was pointed), the smooth edge around the wheel openings (36 has a raised bead), 35 has 2 hood handle per side (front and back corners) whereas 36 has one in the middle, and no extra formed body line around the side window opening (36 has this extra feature). Hood has the round trim circles on the louvers removed. Rear fenders and bed are from something else. Fenders are similar shape but they are too wide (they stick out past the running boards). Bob
I looked at a bunch of pics. It's a 36 Dodge 2dr sedan with a bed .The hood and door mismatch is the way they were made, kinda weird . I'd like to see a pic of the back of the "cab".
Someone said the hood sides are not the same..so maybe custom? If so, maybe it's got a real old time custom nose? I can't tell if the hood has a center hinge...should a mid 30's have one, right? so is the hood custom?
I still say more like a 35 plymouth...check out the windsheild and hood sides. Here is what I found. Dodge Plymouth
Well there you have it, I'd have to say 35 Plymouth, thank you all! White Brothers and Bobper, you know your stuff. It was fun playing name that car with y'all this afternoon....
You and me both, apparently it is still in Mexico, so this might just be the start of an adventure....
Definitely NOT a Hudson or Terraplane. I'd tend to agree with the '35 Plymouth theory. A chopped-back sedan or coupe.
