Spark Plugs pros and cons
Discussion in 'The Hokey Ass Message Board' started by Frenchy32, Apr 19, 2010.
  1. Frenchy32
    Frenchy32
    from arizona
    I would like to hear your feedback as far as is it ok to gl*** bead spark plugs. I know that there is a special coating that is applied on them. Once you have removed this coating may or may not perform the same. Or would it be safer to buy new ones. I know over the years I have had to gl*** beat a few and re install them with no issues. Let me know
    Thanks
    Frenchy
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    do you mean gl*** bead?
    although in reality you are beating them with gl*** beads.
    ive done the sand blasting of them from time to time on old engines that had a tendancy to foul them..but after a few times they became pretty useless
  3. I have used one of these for a while.
    At some point they become worthless, but you can usually get another round or two out of them.
    Best to find the reason for the fouling.
  4. Captain Freedom
    Captain Freedom
    from Upstate SC
    Heat 'em up with a torch.
