Hot Rods Aluminum Radiator, to pain or not to paint? Opinions, advice?
Discussion in 'The Hokey Ass Message Board' started by BIGREDTODD, Apr 20, 2010.
  1. So after getting the runaround from US Radiator, I bit the bullet and bought a Griffin aluminum job with 2 rows of 1 1/4" tubes...but all that's another story...
    My Griffin is here, and looks a lot like the OEM radiator in my truck, which happens to be a 1960 F-100. Thing is, I don't really like having a radiator be a focal point, so I think I'm going to paint it. Not the fins, just the tank, mounting flanges, and sides of the core itself.
    Am I an idiot, is this a bad idea? My engine compartment is understated and simple, just a bit of chrome and an aluminum intake, and I'd rather just let the thing blend in.
    Here's the only old picture I could find.
  2. hotroddon
    hotroddon
    I have painted alunimum radiators black in many of my builds (tanks, core, everything) where an aluminum one would be out of place. makes it just kind of blend in to the core support or grille shell.
  3. onedge
    onedge
    been brought before do a search there where some great methods on making them look the part by painting etc, i need to do the same with one now.
  4. Yeah I know...I just wanted to make sure I wasn't over thinking it. My truck isn't a hard-liner as far as "traditional" is concerned, but I still like to have continuity, and subtlety...
    It's not going to be a hood's up situation at show 'n shines...
  5. 29nash
    29nash
    from colorado
    Yep. It's a preference thing. If the motor overheats with paint on it, taking it off won't help.
  6. kustomrodder53
    kustomrodder53
    I beat myself up over this too. I ended up thinning down some black lacquer by about 50% then lightly "dusted" the front only. It only takes a slight bit to subdue the bright aluminum as seen through the grille, but most of the fins are still untouched and bare.
  7. cullen
    cullen
    from palmdale
    eastwood sells a radiator paint that still transfers heat
  8. Brad54
    Brad54
    from Atl Ga
    I just did a story on muscle car cooling systems, and went to Griffin and talked with them for a day.
    Paint the radiator. You won't have a problem, as long as you don't glop on the paint. A nice even coat of paint shouldn't be a problem.
    One of the things they said that I hadn't thought of was a really good tip: mask off the radiator fins and put a nice heavy-coverage coat on the tank and straps. Then unmask the fins/core, and fog it just enough to cover the aluminum fins.
    -Brad
  9. That's kind of the direction I was thinking too...Griffin ships there radiators with good masking material included, as it turns out, in the form of card stock to protect the fins...
    Thanks for the advice...
  10. Candy-Man
    Candy-Man
    Paint it as posted above. Jeff Norwell has a chopped & painted aluminum rad in his deuce truck which is powered by a 500 (+) HP 392 hemi... Works great....
  11. philly the greek
    philly the greek
    from so . cal.
    My powder coat buddy suggested a product that was some kind of "space shuttle" by-product that he had . It was very thin in consistency , like water , and was applied electrostaticly . It's been on the car for 8 mos. and 5000k miles and no problems at all , by the wat , it's black in color .
