what is this rear end from??
Discussion in 'The Hokey Ass Message Board' started by Rain_man, Apr 21, 2010.
  1. Rain_man
    Rain_man
    hi i have this rear end in my 61 c10 im pretty sure it is not stock from what i know the truck had a gm 10 bolt from the factory
    thanks for all the help
    p.s. i have asked a few guys and everyone just says oh ya it is a gm 12 bolt i need to know what it came from im wanting to upgrade my rear brakes/switch from 6 to 5 lug
  2. shinysideup
    shinysideup
    from ruskin, fl
    Scope out the tag and casting numbers. It helped me de-code mine.
  3. Loadedagain
    Loadedagain
    what is the hub to hub dimension?
  4. 40hemicpe
    40hemicpe
    from anaheim.ca
    looks like a dana but not sure on the series?
  5. PxTx
    PxTx
    from PA
    Looks just like the 12 bolt truck rear in my friends 1967 Chevy short bed. Same suspension and pan hard too!
  6. Brad54
    Brad54
    from Atl Ga
    That's a 1964-up GM truck 12-bolt.
    The Dana 44 has 10 bolts.
    The '60-'62 trucks had either a drop-out center 10-bolt with a round bowl-like rear cover that bolted on, or the Dana 44.
    The '60-'62 Chevy and GMC trucks had a pan-hard bar mount on a big bracket way in the middle of the p***enger-side axle tube.
    1963 was the first year for the 12-bolt, and I think it also had the panhard bracket in the middle of the tube, but the trailing arm brackets are different... different angle than the '60-'62 trucks.
    The '64-'66 trucks (and maybe later) had a shorter panhard bar, mounted to an ear cast into the center section, as shown on yours.
    Note that your panhard bar has been shortened.
    -Brad
  7. Verbal Kint
    Verbal Kint
    from Washington
    An old timer found me a set of 1974 chevrolet impala wagon axles in a 5x5 lug that fit my 1970 C-10.
  8. Rain_man
    Rain_man
    thanks
