Supremes coming apart...yikes!
Discussion in 'The Hokey Ass Message Board' started by Goozgaz, Apr 22, 2010.
  1. Goozgaz
    Goozgaz
    I've heard about guys welding reinforcement plates to the rear of the spoke because they used to break off.
    Here's what happened to me today.
    Check out how the backing plate that USED to be welded behind the spokes is now in between the spokes.
    YIKES! This broke while driving down the road today. Luckily it was a city street and I was going slow.
  2. BuickBorracho
    BuickBorracho
    WTF? Are those made by US Wheels?
  3. Shawn M
    Shawn M
    I'm ***uming these did not have the extra plate in the back? That is scary though, you must be living right! You could've been strolling down the interstate when it let go
  4. Hi!
    Hi!
    from SoCal
  5. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Go buy a Lotto ticket, today is the day for you.
  6. Squablow
    Squablow
    Yikes! I thought the rumors of these breaking were just ********. Is this a new wheel, or an old one? Do you know who the maker is? How did the center not come out of the hoop?
  7. There is something to hang on a wall!
  8. chevy57dude
    chevy57dude
    Time to shop for a different brand of wheels! Wow! How does this happen? You weren't doing a holeshot on slicks or anything, so what gives?
  9. c57heaven
    c57heaven
    Wow! glad to hear you and the car are ok. That could have been messy.
  10. Nominal
    Nominal
    The wheel is still attached to the car though, right?
    Can you take a pic from the back of the wheel when it's off the car?
    I have Supremes of some sort on my Merc and would like to know what to match out for.
  11. Kail
    Kail
    from Austin, TX
    I was just looking at getting a set for a project, if I run them this will be in the back of my head... steelies are looking a little better right now.
  12. Goozgaz
    Goozgaz
    I wasn't doing anything but driving down the road.
    The wheels are an old set that came with a wagon I bought about 4yrs ago.
    They don't have a name brand.
    Scary shiiiiit.
  13. plymouth1952
    plymouth1952
    wow thats put my choise of rim on the shelf. can you say what brand so others wont get hurt. glad your ok
  14. Goozgaz
    Goozgaz
    They don't have a brand name anywhere. Only stamping says 15 x 6
    Here's a shot of the backside. The whole center section moved over a couple of inches. I bet if I gave the center section a good kick it would fall right through since it's now just wedged in the wheel.
  15. Slickster51_50
    Slickster51_50
    Wow i hope mine don't do the same when i get my coupe on the road!I have a slick on mine so now i may be looking for a different set to run.
  16. looks like they never welded the spoke to the rim!
    the spoke should be welded to the rim first then the plate for reinforcement, im glad this did happen to you on the highway.
  17. ryno
    ryno
    dont know what to say....wow is the only thing that comes to mind
    kind like the staples commercial, WOW that was a good deal.
  18. CraigR
    CraigR
    That's a good point - obviously the center is chromed first - looking at the back of the rim, how could they weld the center to the rim with enough penetration to do the job, without ruining the chrome? Are they all made this way?
  19. Kan Kustom
    Kan Kustom
    Are spinner wheels traditional ?
  20. Kona Cruisers
    Kona Cruisers
    ....... x2!!!!!!!!!!!!!!!!!!
  21. they are already chromed when they are put together. i have seen them crack the hub from were the spoke is welded to the hub many times but never seen one come apart like that. i have seen some that are tagged as being for show use only not for the streets
  22. 39cent
    39cent
    from socal
    looks like only the edges of the plates were welded and over time could flex and finally! BANG!
    ohh well it must have been Monday!
  23. Slickster51_50
    Slickster51_50
    Mine are welded in the same fashion as these kinda makes me leary about running mine now!
    Mine aren't welded in the inside of the spoke either.
  24. MilesM
    MilesM
    Holy ****! I had a set with reinforcement plates on my 3/4 ton 54 pickup but still did not have a good feeling about them even with the reinforcements. Glad I pulled them now.
  25. The Law
    The Law
    from N. AZ
    I heard that they are made differently now because this was a semi-common failure for these wheels. Any truth in that?
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    That would explain the lack of manufacturer or brand name on the wheels.
  27. flynbrian48
    flynbrian48
    You are a lucky pup.
  28. TMoney
    TMoney
    I've heard that new Supremes are made better. I sure hope they are. You are one lucky man.
  29. forty1
    forty1
    This isn't a CRACK is it?
  30. ZomBrian
    ZomBrian
    from in IN
    Glad to hear you're OK Goozgaz. This is just proof to anyone interested in welding that the first thing to achieve is penetration and not just a clean bead.
