Riveted rims, bias plies, liner or no?
Discussion in 'The Hokey Ass Message Board' started by paulie_boy13, Apr 22, 2010.
  1. paulie_boy13
    paulie_boy13
    from NC
    I have a set of 15" 1953 Merc riveted rims. I have a set of Goodyear super cushions to go on them. I also have a set of tubes and stems.(from kelesy tire)
    Do I need a liner over the rivets ?
    ( anywhere you recommend that sells em? My local couldn't get them)
    will electrical tape work if I can't find a liner? It's not a "fiborous" type tape.
    Thanks
  2. thunderbirdesq
    thunderbirdesq
    Ive never run a liner on any of my cars with riveted wheels and I've never had a problem. As long as there are no sharp spots you'll be fine.
  3. scrap metal 48
    scrap metal 48
    What thunder said...........
  4. AJofHollywood
    AJofHollywood
    Liners are usually used with older wire rims. And as Thunderbirdesq wrote, make sure there are no sharp edges or metal things sticking up and you'll be fine.
    I always do a though inspection on the inner rim before I have a tire installed.
  5. Maco-B
    Maco-B
    Tape's fine...I.M.O. a little Xtra does hurt.
  6. Boones
    Boones
    from Kent, Wa
    do you really need tubes
  7. Deuce Roadster
    Deuce Roadster
    I have run mine ( 1956 F-100 and 1948 Mercury ) with no tube.
    I run tubeless tires :D
  8. flynbrian48
    flynbrian48
    My '51 Pontiac has riveted rims, and I'm running tubless radials. The guys at Discount Tire freaked out, but they don't leak!
  9. Tank
    Tank
    ive got a '53 Merc. with the original rims still on it, and I didnt run liners or tubes. 7.10 15s Firestones. Been on for several years with zero trouble.
  10. flatheadjunk
    flatheadjunk
    from Orange CA
    Please don't run riveted rims-----my pal stuffed his roadster into a guardrail due to some being rusty and they snapped.Everyone should true the wheels and at least tack 'em. I am a very traditional car guy but some stuff is just flat out dangerous.
