how do you tell the diffrence between a th350 and a th400 can we have some pictures of the diffrences ..thanks...
The pan on a 350 is rectangular with the corner cut off. There are charts on the internet that show you, I can't link up stuff from work.
hmmm on the chart the trans pan on a th350 is smaller than the th400 but on my trans i have the cooler lines and the vac*** asembly on the p*** side ...??
A 350 isn't as strong, but are still very strong. If you don't have a super high horse motor, might as well use the 350. They use less hp, and if you go to a 4 speed later, very little has to be changed. 400's are good too.
