Hot Rods No paint and run this summer or wait?
Discussion in 'The Hokey Ass Message Board' started by bloodyjack, Apr 23, 2010.
  1. wait and paint
    30 vote(s)
    42.9%
  2. run bare metal
    40 vote(s)
    57.1%
  1. bloodyjack
    bloodyjack
    <o:smarttagtype namespaceuri="urn:schemas-microsoft-com<img src=" images="" smilies="" redface.gif="" border="0" alt="" ***le="Embarr***ment" smilieid="2" cl***="inlineimg"></o:smarttagtype> I am still in sheet metal repair land with my build and it seems to be taking ages.
    I still have a door to repair and the rear quarter panels to finish then weld it all up.
    The plan was to then ship the body off to my buddy for finish weld block and paint
    And I would finish the rolling ch***is (brakes, steering and wiring left to do)
    I know it will take about 6 months at my buddies (or more)and I would lose the summer.
    Do I leave the body bare metal and get it running for the summer and give the body to my buddy in the winter for prep and paint or wait until I can have a finished paint job?
    Remember this is rainy <st1:city w:st="on"><st1>Seattle</st1> </st1:city>but I don’t intend to run in the rain only a handful of the cool shows (Billetproof, hotrodarama)
    I am thinking run it and forget fixing the rot in the door a replacement might show up between then and now I just don’t know if I can handle the “nice rat rod” or the “be cool if it was finished” quips I am going to get from idiots
  2. John 79
    John 79
    from Sweden
    Drive it.
    Its perfect to try your ch***ie one summer and if you wanna do some changes you can do them when the body is at your friend.
    Theres no better insperation than a drive with your car.
    Great lookin Hot Rod by the way,looks "real".
  3. Sir Woosh
    Sir Woosh
    Till it's neater, call it a beater. Seems to be a lost term for cars that were being driven while being finished. Doesn't mean it's going to be a permanent rat..............
  4. The Hank
    The Hank
    from CO
    Wait , it will take forever to sand the rust off later.
  5. SHRUM
    SHRUM
    Just throw a coat of black gloss on it to get the bugs worked out. Then paint it for real this winter.
  6. Mr48chev
    I'm no fan of the bare metal thing except to take it out to the Unfinished Nationals or another event for a "here it is" first time showing before taking it back to the garage for the finish work.
    That said, there is a lot to be said for putting some miles on it and getting things sorted out before doing the final finish work and paint. It's a little bit easier to feel like diving into it an fixing or changing something before it has the finish coat of paint an the upholstery done.
  7. BettyBlue
    BettyBlue
    Prime it or roll it like it is... My 41 Plymouth is getting her chop done before Paso Maria and then fender moloding and etc after...so all the shows this summer, it will be in varying states of dissaray... I just tell 'em its a Cadi motor and a beater body, if they dont like it, **** off...
  8. xsquiden
    xsquiden
    I plan on putting a quick coat on mine for the summer so i can do the body work slowly but still drive to work the bugs out then when the body is done blow it completely apart and finish everything.
    later
    mike
    btw that thing looks like lots of fun
    oh yeah if people dont like my car they can buy it give me the money to finish it or shut the hell up
  9. Big Nick
    Big Nick
    I agree, quick coat of something to protect the metal and run it. Get the bugs out, see what needs to be changed, perfect chance for all that is now.
  10. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Rattle can it quick and run it like that, or get a cheapy hvlp and roll it outside one day and bomb it with rustolium.
    I ran my car for a summer with rattle can before i painted it.
    Hell, i ran it like this to its first show!
  11. lorodz
    lorodz
    keep it bare and roll out ,,,,its ready to go ...
  12. x2!:cool:
  13. xtralow
    xtralow
    protect it and run it for the summer.
  14. Verbal Kint
    Verbal Kint
    from Washington
    A quick once over with the color du jour just to keep the rust and "comments" to a minimum. Details may change after you drive it awhile, if you slammed it out they may never get changed.
  15. bloodyjack
    bloodyjack
    So I am going to order 8 cans of spraymax 2k epoxy in a can
    not cheap ($17 a can) but better than store rattle can primer
    U break a valve in the base then shake too mix the 2 parts and wear
    breathing gear.
    http://www.repaintsupply.com/pd_2_part.cfm
    I used there 2k clear coat for the paint job on the Schwinn I got for my daughters xmas present and it turned out great
  16. When I get mine running/driving, you can bet your sweet *** I'll be dring it unfinished for at least a little while. I do applaud your decision to protect it until it's final finish.
  17. need louvers ?
    need louvers ?
    That's what Gibbs oil is for! Rub it down and party on! After a whole summer driving it you'll be bound to find something you want to change any way... As far as the quips... I find the term "blow me" works pretty well, or "Thanks, where's yours?".
  18. davis574ord
    davis574ord
    I would seal it with a catalized sealer and get the bugs worked out of it before you paint it!
  19. Retro Jim
    Retro Jim
    Primer shoots fast and is cheap plus it will protect the metal from RUST !
    Now go out , drive it and have some FUN ! :D
    Retro Jim
  20. plymouth1952
    plymouth1952
    no way the rust dog will bite you in the *** where you dont expect it.
  21. sensor
    sensor
    hit it with metal prep(sorry im a ppg guy)and roll it. itll be protected and then you can still finish it w/o having to deal with rust or unwanted paint/primer later....as for the nice ratrod or whens it gonna be done comments....thats what your middle fingers for
  22. 29nash
    29nash
    from colorado
    Drive it. Why spend $300 on a paint job when it can be used for beer.:D
  23. rivguy
    rivguy
    I would say run it the way it is for the summer, but protect the metal with the waterproof primer or it will just rust over again. You can work out any bugs or make any changes and then detail it out for next year.
    I'm using the time honored, broke guys method with a spray bomb primer coat.I just want a consistent color while i shake down my Riv, hopefully for Santa Maria.
  24. Dzus
    Dzus
    As wet as it is there I would not run it bare. I'd also be paranoid of oiling it if you plan on putting a decent paint job on it down the road. I'd put a temp coating on it and drive it while you work on. You can blow it apart and do it right next winter.
    I liked using the old alkyd (synthetic) enamel primer-sealer for a temporary coating. It was cheap. It comes off easy for doing your metalwork as you work your way around the vehicle. The primer-sealer was a hair more rust resistant than the primer-only version and you could get one season out of it. It was also a semi-gloss finish and looked better. I did a quick web search and it looks like it still available.
  25. 1964racecar
    1964racecar
    Your car looks great. I would put the PPG wash primer on it. It has a cool green color and when your ready for prime you just scuff and shoot Dp.
  26. philly the greek
    philly the greek
    from so . cal.
    Since you live in WA , I'd use the warm summer months to do all the paint work since it'll take a while to do a nice job . Then use those cold wet months to take your time doing the re-***embly and be ready to do the big debut next year .
  27. HotRod33
    HotRod33
    PRIME IT and DRIVE IT.....
  28. busch
    busch
    Rattle can drive it have fun
  29. Yup and that snowboard hanging on the wall tells me you have other things to do next winter. A T is not that big, I was at this point about 5 years ago and took an extra couple months and got everything in paint..
  30. 64LeSabre455
    64LeSabre455
    from Adkins, Tx
    I had the roof of my 64 in bare metal for last years Billetproof. I was going to get around to throwin some paint on it, but one show ran into another, and guess what....
    It still isn't painted.
    Throw something on there to protect it and drive the **** out of it!!
