Bonneville styled 1932 tudor build
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Oct 17, 2009.
  1. Salt Flats Speed Shop
    from Utah
    I agree with you that it drew your eye to it immediately. I took one if my small blisters I had laying around and mocked it up. Im thinking if I re-shape the pitman arm to be more rounded like a ford arm that I could just run it like it is.
  2. K13
    K13
    Yeah that looks way better!!
  3. JeffreyJames
    JeffreyJames
    from SUGAR CITY
  4. -Brent-
    -Brent-
    Even with the bigger blister, I kind-of think that it'll blend in once there's paint on the car. The blister does have a function, too... so I don't mind it as much as. I think I might like seeing the arm and blister only. After all, the idea of having a blister is to cut resistance and keep debris away.
  5. floored
    floored
  6. krylon32
    krylon32
    from Nebraska
    I toyed with a blister on my last roadster (HopUp 10) and just ended up with the steering coming out the side of the cowl with nothing but a polished ring held by ****on heads. My steering was a little tighter to the body.
  7. brady1929
    brady1929
    no blister looks good too
  8. milkweed
    milkweed
    from SLC UT
    The smaller one fits the picture alot better.........
  9. Salt Flats Speed Shop
    from Utah
    Went ahead and made a small blister. Just need to mount it, but its all done.
  10. K13
    K13
    That rules Chris! Much better choice than the huge one.
  11. krylon32
    krylon32
    from Nebraska
    My girlfriends always used to say size does matter! But sometimes smaller is better?
  12. -Brent-
    -Brent-
    If we're talking about your blisters, then yes, I think? :D
    brEad likes this.
  13. hellonwheels
    hellonwheels
    from Bastrop
    Wow Chris, that looks awesome. This car just gets better and better.
  14. Pewsplace
    Pewsplace
    I love the small one and it will look great and different than everyone elses cowl mounted steering. You have a good eye for a youngster.
  15. 3wLarry
    3wLarry
    from Owasso, Ok
    man, you're just movin' right along...cool beans
    kidcampbell71 likes this.
  16. hechtspeed
    hechtspeed
    That does look more period correct in a way. I like either one.
  17. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Nice. The smaller one is right on point my good friend. Great work.
  18. Salt Flats Speed Shop
    from Utah
    I worked today on getting the headlights mounted on the car. I used an original headlight bar, and cut the ends off. Then added more tubing to the cut off ends, and bent them and welded them to the back side of the headlight bar. Kind of has that floating effect which I like.
    Man I love huge headlights!!!
  19. Corn Fed
    Corn Fed
    Nice headlight Bar!! I like how you reused the fender pads to mount it to the frame.
  20. hechtspeed
    hechtspeed
    Agreed Chris, big headlights looked great! Man! This is one cool rod! I know I'm the first one to say that. haha
  21. -Brent-
    -Brent-
    Looks aggressive, I like that!
  22. brigrat
    brigrat
    from Wa.St.
  23. Master of None
    Master of None
    I had a client with a O/T 79 Trans Am I was re-painting. He told me under an influence of a couple of beers (I hope) that he was clocked doing 200 MPH! Mind you this is a stock 403 automatic car that I'm sure he haddn't changed the plugs since new in 79. " Yeah the cop said my tires looked like pizza cutters".
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Nailed it... wow.
  25. freebird101
    freebird101
  26. 35ratbstr
    35ratbstr
    from Colorado
    Great Job & nice metal work!
    One question; where are you going to mount the fuel tank? No rear frame rails, rear seat???
    You are a very talented person and obviously your dad must be a good mentor.
  27. Buddy Palumbo
    Buddy Palumbo
    The car's coming along very nicely !
  28. Salt Flats Speed Shop
    from Utah
    I'm planing on building a gas tank that goes behind the rear seat. It will contour along the back sheet metal, and be as tall as the rear window. Probably will be around 4" thick at the smallest, and when it transitions around to the side wood it will be 7" thick. And with it being 3' tall should hold a decent amount of fuel.
    I don't want to mess up how clean the back of the car is. So I'm thinking of using some of that flexible style tubing like they have on old Jerry cans and have it so you roll down the side window and grab the tubing, bring it out the window, and then fill it up outside the car.
    If anyone has any other thoughts on how to fill up the gas tank without putting in some outside filler door I'm defiantly up for suggestions.
  29. draggler
    draggler
    Jealousy,envy ,,not enough words for my description! Oh wait 7 deadlies! Knockout ! Im getting chills ,there multiplying,,and im losing control .
  30. brigrat
    brigrat
    from Wa.St.
    Isn't it funny how a simple thing like a gas tank filler can cause so much grief! You will have to run a lisence plate maybe you could hide it behind if it's not to low, or maybe a sprint car type cap would blend in like CraftyB sells?
