Strange vibe..
Discussion in 'The Hokey Ass Message Board' started by The Loser, Apr 29, 2010.
  1. The Loser
    The Loser
    from OKC
    Hey , Got a 38 chevy PU on a 82 s10 frame runnin a 305/700R W rubber mt trans and 55-57 chevy ft motor mounts, w rubber biskutz. New custom driveshaft, balanced. all rear/ft end and frame stock st, just axle flip. Motor came with the flywheel and balancer, and trans came w converter. both used. I know this does not make it right, but cuts out the NAPA factor....Have a vibration that runs front to rear every 3-5 seconds or so....while rolling, not under throttle only ..rear end crooked? driveshaft mis bal? wrong flywheel/conv? crooked drivetrane? Should i solid mt the trans? my lokar nostalgia is beating me to death, help!
  2. THE_DUDE
    THE_DUDE
    Did ya try puttin the fenders and runnin boards on?
  3. vivalahotrod
    vivalahotrod
    That's funny right there.
  4. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Id try that first.
    Might just be the car shivvering from seeing itself in window reflections. :D
  5. firingorder1
    firingorder1
    Could be a "deth wobbel".
  6. oldcarfan
    oldcarfan
    from missouri
    some of you guys are just plain ****ing great.
  7. Check pinion angle... also, do the U-joint holes line up really well from one end of the driveshaft to the other?
    Just a guess. At least as likely as the fenders...
    One more possiblity: lean mixture or other misfire at cruise? Just throwing that one out there.
    BTTT for someone to 'crystal ball' this one.
    -Bill
  8. H3O
    H3O
    could be the tires not balanced.
    if your name wasn't the loser then there wouldn't be an issue either.
    one heck of a name you picked for yourself.
  9. screwball
    screwball
    A sense of humor does seem to be lacking on this site most of the time. WITH all the modifying have you done an alignment? There are LOSER car clubs all over the world so your not alone dealing with all the Im better than you ****. But some people need to be better than others to keep there egos inflated.
  10. The Loser
    The Loser
    from OKC
    Thanks for real help! Just want some opinions to start with. If I wanted everyone to laugh at it id go back to wallmart in it
    fender nazis.
  11. The Loser
    The Loser
    from OKC
    No I have not tried that, Will today! Thanks alot, one loser to another.:cool:
  12. borndead327
    borndead327
    hahahahha new guys
  13. 61falcon
    61falcon
    things to try that will help give some direction. does it change if put in nuetral, how about finding an empty road and getting up to speed and kill the motor, if gone its engine/trans. if still there, its driveline or tires. try different tires/rims if available (got a buddy's car with same bolt pattern). do you feel it in the steering wheel, floor, or seat of the pants? is the exhaust hitting anything, are the exhuast hangers solid or have rubber hangers?
  14. Fordguy321
    Fordguy321
    from Arizona
    yep the muffler bearings are worn out!
  15. screwball
    screwball
    Just find a hot rod or modified friendly shop and get the whole thing checked over bumper to bumper. If you have bumpers.
  16. wasn't me
    wasn't me
    from texas
    The 305 takes a balanced flex plate (flywheel), is it possible you have one from a 350 with no weights it could be the cause of your problem
  17. 49ratfink
    49ratfink
    I have heard people speak of vibrations and whatnot from messed up pinion angles before. I had a 49 Chevy sedan where the trans was 3 degrees down, and the rear was 4 DEGREES DOWN!!! NO ****!! the rear end pads were welded on for some other car, then later just bolted into the chevy without checking anything. previous owner did it... not me.
    I noticed absolutely no difference in vibration or anything else after I fixed it. my u-joints sent me a thank you card, but that's it.
    the original V8 chevys with front mounts had mounts at the bellhousing, and I believe the trans just hung out in the breeze. might not solve the problem, but I'd say go with side mounts.
    I'm thinking if a motor imbalance was the problrm you would notice it while revving in neutral.
    ... you know what? I'm having troubles on my own car right now. I know where there is a good cliff we could both shove our cars off and then we will have no problems at all and a happy weekend... what do you think? I'm ready and I'll even go first.
  18. The Loser
    The Loser
    from OKC
    Nuetral no change, or killing the motor, I noticed the only thing suportting the heavy SS mufflers atre the hreader bolts and 1 rubber mt. Im thinkin that is a problem. Thanks alot for the great advice!:).
  19. The Loser
    The Loser
    from OKC
    See, thats what I thought, Turns out it may be incorrect blinker fluid viscocity. :confused:
  20. The Loser
    The Loser
    from OKC
    error
